Lawn Mower oil?
Originally Posted by RyanMiller
small engines without a oil filter need a non detergent oil, so that the dirt settles on the bottom. this helps the engine clean it self, and not wear out. most automotive 10w40 is detergent, and will wear out the mower easier.
Briggs use 30wt motor oil only !!!!!!! I have been doing this from 1978 & still doing it, Never use synthenic oil or muliti blend oil If ya don't beleveve me run it Briggs will love ya what's $$$$$ or you could send me the money !!! I could use it . 10- 30 or 10 -40 will foam up in air cooled engines . Water cooled no problem use it .
Don
Don
Use what the manual says to use.
I've been building/re-building Briggs & Stratton, Tecumseh and some Clinton and Lauson engines since I was 13. (Over 37 years.) First engine was a 3 hp B&S model 5BH. It STILL runs.
At the moment, I have two identical push mowers with B&S 5 hp engines, and they call for 10w-30 oil. These engines are 1989 model engines and use NO oil. Not a leak, either. (Engines have NOT been opened up. Ever.)
I also have an MTD mower bought from Wards w/ a 16 hp Briggs and Stratton I/C engine that calls for 30w.
It is a 1992 model and it uses NO oil. No leaks. (Engine has NOT been opened up. Ever.) Only replaced part is the ignition module.
Since day one, all of them have had what was called for in the manual.
The oil I use. . . . Penzoil. 30w is HD (High Detergent.)
Bottom line. . . . use what the manufacturer calls for in the manual and maintain the engine! That's the most important step. Maintenance.
Just my 2¢
Just my 2¢
Originally Posted by snyiper
What we need are some bullet proof decks to go with the engines!!
As long as Lowe's, Home Depot, Sears, Ect. are selling any type of lawn Equipment !!! They will mostly be JUNK, they are selling them selfs they don't stand for the manufactures. The Japanese woke up the americans & we now build much better Cars & Trucks, And until people wake up , or the Goverment step in - because the land fills are filling up with Junk,we are stuck with this stuff !!! I sell Dixon ZTR's & Kawasaki power equiment blowers, trimmers ect. none of these are sold at the Junk Stores! If you think about it it makes sense to me ! If the equpment is so good why don't thay fix it . But for sears just figure out how much they charge to fixem when thay are new they charge to fix em while they are still under warranty. Just a thought !
Thats just me standing on a pedestal !
Don
Don
