How do you start it without the key? - Ford Truck Enthusiasts Forums
Old 02-17-2005, 08:36 AM
ford fisherman ford fisherman is offline
ford fisherman is starting off with a positive reputation.
Picking up a 1968 F100 short bed with a 360 in rough shape. I would like to try and get it started today but the guy has lost the key. What is an easy way to do this without the key.
Thanks for any help.
Old 02-17-2005, 09:07 AM
7283-F250's Avatar
7283-F250 7283-F250 is offline
NH Chapter lean pawn
7283-F250 is a name known to all7283-F250 is a name known to all7283-F250 is a name known to all7283-F250 is a name known to all7283-F250 is a name known to all7283-F250 is a name known to all
I know that jumping the starter solenoid with 2 screw drivers (one on each of the big bolts sticking out from the sides and than touch the screw drivers together) will turn the starter over but without the key in the accesory position it will not stay running.
I just had a thought. The ignition is fairly easy to get at so you could buy an ignition put it in and start it up. Or I am sure there is someone on here that could say "cross these 2 wires than jump the solenoid".
Old 02-17-2005, 09:10 AM
I know how to jump the solenoid but I do not know how to make the points in the ignition switch line up to keep it running as you pointed out. I was thinking about punching through with a screw driver for now but do not want to make things worse.
Thanks for the reply.
Old 02-17-2005, 09:32 AM
Unimog005's Avatar
Unimog005 Unimog005 is offline
Unimog005 is starting off with a positive reputation.
Go to your local salvage yard and get a replacement Ig switch with keys.....you can hook it up under the dash by just swapping wires....and you can install it as a replacement once you get home. Not hard at all.
Old 02-17-2005, 10:59 AM
wheelhoppin67 wheelhoppin67 is offline
wheelhoppin67 is starting off with a positive reputation.
there are three wires comming out of the ig switch, i used to hold two together and tab the third one to start it, you would have to play around and see which two wires are suppose to be connected
Old 02-17-2005, 08:42 PM
DAV1972 DAV1972 is offline
DAV1972 is starting off with a positive reputation.
To "hot wire" the truck you need to run a wire from the battery to the positive on the coil. Then you do the screwdriver thing on the solenoid. Alot of the electrical will not work like turn signals. Also you run the risk of burning the points and overheating the coil so I would suggest just getting a new switch with key.
Old 02-17-2005, 09:32 PM
yaki69 yaki69 is offline
yaki69 is starting off with a positive reputation.
i know when you are running a compression test, the hand held starter to test for compression will start it, if all wires are on. ive seen it done once on an old dodge, but i think it should work...
Old 02-17-2005, 09:55 PM
crecity678 crecity678 is offline
crecity678 is starting off with a positive reputation.
simple jump the two big wires from the ignition, remember you have to take them apart to turn the truck off. looking on the starter selinoid note the color and pattarn of the smaller wire closer to the battery(red and blue i think) jump that against the two big guage wires you connected under the dash until it starts then seperate that wire from the rest and drive on
Old 02-17-2005, 10:48 PM
orich's Avatar
orich orich is online now
orich has a great reputation on FTE.orich has a great reputation on FTE.orich has a great reputation on FTE.orich has a great reputation on FTE.
Hmmm only one ez way.
1. Run a hot wire too the+ side of the COIL.
2. jump from hot batt. side of solenoid TO (S) ON THE solenoid TOGETHER.
3. make sure it's in part
4. when you want to shut the engine off (REMOVE HOT WIRE)
TO push start with out a key. Yep hook up just hot wire to + of coil
and push it as fast as it takes to kick in to gear..
Don't worry about the points getting cooked for a short run as your going to be doing
Old 02-18-2005, 08:15 AM
Thanks for all the advice fellas. I lucked out and he had found the key. Still could not get it started. The truck had sat for a couple of years. Pulled out the old fluids and put in fresh but I think the carb was to varnished. It did turn over though but seamed like the starter was dragging. Going to rebuild the carb and see if I can get her to fire.
Thanks again.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
