Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > 401, 477, & 534 SD Engines
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 02-16-2005, 07:36 PM
zwinstead's Avatar
zwinstead zwinstead is offline
1995 Ford F-350
My Garage
zwinstead is starting off with a positive reputation.
Any F600+ Owners out there??
I'm looking for info on a driveline mounted parking brake setup. I have a 1977 2wd F-250 with a T-18 4 speed. I think I could use this set up from a medium duty when I convert my truck to disc brakes. I have gotten no response on other forums. I thought I might find some big truck owners here.... Thanks
__________________
Zac
77 F-150 472, C-6, 3:50 / 77 F-250 408, C-6, 4:10
95 F-350 7.3L, EC, DRW, 4:10 / 87 Ranger 2.9L, Driver
  #2 (permalink)
Old 02-16-2005, 09:30 PM
Birken Vogt Birken Vogt is offline
Garage is empty, add now
Birken Vogt is starting off with a positive reputation.
I don't think any medium trucks used the T18. They might have used a NP435, but probably were usually bigger than that. You could just put it in first gear to keep it from rolling away
Birken
  #3 (permalink)
Old 02-16-2005, 09:52 PM
zwinstead's Avatar
1995 Ford F-350
My Garage
Its not the trans I'm after its the parking brake that goes on the back of the trans. I can adapt it to my tranny.
__________________
Zac
  #4 (permalink)
Old 02-17-2005, 07:14 AM
HOTWRENCH HOTWRENCH is offline
HOTWRENCH is gaining momentum as a positive member of FTE.
Some of the older Fords IHs @ Jeeps used the driveshaft mounted E brake witha T18.
I hope this helps HOTWRENCH
__________________
FERGUSON'S GARAGE est. 1967
car , truck , heavy equiptment repairs
4 X 4 specialists PORTABLE WELDING SERVICE
TOWING New @ used PARTS
1981 L 800 460 5 speed , 2 speed rear
1957 F 600 390 5 speed
  #5 (permalink)
Old 10-16-2005, 12:20 AM
davethecow davethecow is offline
davethecow is gaining momentum as a positive member of FTE.
Evan the clark 5 speeds that are in my f700s had the e brake at the back of the tranny.there removable and the only thing i can see is that you might have to shorten the drive line a bit.
__________________
High desert.Mountains.Clean air and no smog.In the Nevada chaptor
73 K-10 short box 4x4 Chevy 396,th400,np205,dana44/60. 74 Ih100 short box 4x4 International 392,t-18,np205,dana44/60
75 f100 short box 4x4 Ford 390,np435,dana 20,dana44/60. 76 j10 short bed 4x4 Jeep 390 th400,dana300.dana44/60
78 w-100 short box 4x4 Dodge 383,np435,np203,dana44/60. 81 Jeep waggy rock crawler
  #6 (permalink)
Old 10-16-2005, 12:43 AM
budman-mo's Avatar
budman-mo budman-mo is offline
budman-mo is starting off with a positive reputation.
Hmmm.....DS parking brakes are somwhat optional, they just mount on the rear of a trans, I doubt if the trans maker even makes them. The trick would be to find or machine the spacer/mount that it mounts to then you could mount it on anything (with DS alterations). That spacer usually holds the rear seal and spedo gear too. Most all trucks had them untill the 80s when they started using the gerling style hydraulic emergency brakes on the rear axle on some (Fords). I would guess the trucks with rear disc still have them. You could go hunting at any medium truck/school bus salvage yard for ideas. You could always use the Ozark method, a couple sticks of firewood by your tire, that works real nice.
Tags
60s, brake, brakes, driveline, duty, f600, ford, hydraulic, medium, parking, parts, t18, tf727, troubleshooting, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
