88 302 EFI Serpentine belt problem - Ford Truck Enthusiasts Forums
1978 - 1996 Big Bronco SPONSORED BY:
Old 02-16-2005, 12:36 AM
FordPickup460's Avatar
FordPickup460 FordPickup460 is offline
FordPickup460 has a great reputation on FTE.FordPickup460 has a great reputation on FTE.FordPickup460 has a great reputation on FTE.FordPickup460 has a great reputation on FTE.FordPickup460 has a great reputation on FTE.
88 Bronco 302 EFI AOD AC
We had the air pump go out and dont have the money to buy a new one, so we tryed to bypass that and the AC pump by using a shorter belt. The belt we have was the smallest one we could find at Schucks or Napa, 83 1/2". Its too loose, slips on the crank and water pump pulley. Anybody know where I can find a 82" 6 rib belt ? Any other ideas ? Were short on cash and need to get this on the road. Thanks, Trey.
Old 02-16-2005, 01:49 AM
kameronth's Avatar
kameronth kameronth is offline
kameronth is gaining momentum as a positive member of FTE.
I am not sure where to find that size, but if you leave your smog pump off for too long it can mess your cats up.
Old 02-16-2005, 02:15 AM
There are no cats. Tookem off cuz they were bad and replaced with pipe and a cherry bomb. No emissions here where its registered.
Old 02-16-2005, 03:35 AM
JBronco's Avatar
JBronco JBronco is offline
JBronco is starting off with a positive reputation.
I believe that there is a pulley made to put in place of the pump so that you can use the regular belt. I don't know who makes them or where you buy them. I would start by going to an auto parts store and asking them, or try a Google search. I wouldn't think that it would be too expensive.
Old 02-16-2005, 10:20 AM
Kemicalburns's Avatar
Kemicalburns Kemicalburns is offline
Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.
summit sells a smog pump eliminator for your motor. pretty cheap to. that should take care of you
Old 02-16-2005, 11:35 AM
JBronco's Avatar
Quote:
Yeah, that's it. Thanks Kem
They make them for A/C compressor elimination too.
Old 02-16-2005, 10:02 PM
Thanks guys. We got it fixed.... for now. We took the AIR pump apart and cleaned it out and packed the bearings with grease. We are planning on gettin the parts from summit to do away with the pumps, but dont have the money now and needed to get the thing on the road.
belt choice dorymate88 Engine Swaps 0 12-13-2011 07:39 PM
serpentine belt help dorymate88 Engine Swaps 3 07-03-2011 11:42 AM
Goodyear Gatorback Belts tdcarter72 1987 - 1996 F150 & Larger F-Series Trucks 4 10-07-2010 09:48 AM
88 302 belt routing......... mjstef 1987 - 1996 F150 & Larger F-Series Trucks 1 07-03-2007 03:46 PM
Question serpentine belt size difference on my 1992 Ford F-150 302EFI Jrock909 1987 - 1996 F150 & Larger F-Series Trucks 1 08-27-2004 09:36 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
