You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
What are the spring rates for the 1st gen coils and leafs? I installed 1st gen coils and leafs on my truck ('94 swb, 4.9l, E4OD) along with Bilsteins (ak1289/1290). The rear is firmly planted but the front is a little bouncy. I also replace all the bushings with urethane and added front and rear swaybars. I'm thinking I need the shocks revalved or de-gassed to get both ends acting the same. My engine is only a little lighter than a 351W. 20 lbs lighter according to most weight lists. Thanks.
They're supposed to be the same (rating) as a standard F-150. The shocks are more performance oriented, and they have a bigger sway bar as compared to a regular 2wd f-150. Bilstein makes a shock for the GEN 1 L's that is much like the ones used on the GEN 2 L's. The ride overall ride is supposed to be like a stock L, but some said that they seem to be just a bit firmer than stock.
__________________
Matt C.
Intercooled Vortech, Victor Jr. heads, roller cam, 62lb injectors, 2800 stall converter, Eaton Locker, Pickrel Headers and Exhaust, FMS Mass Air using SCT tuning software. Road trip and dragstrip ready!
