88 Bronco II - Intermittently Stops Running - Ford Truck Enthusiasts Forums
Bronco II Ford Bronco II
Old 02-14-2005, 08:50 PM
Ergoittiam Ergoittiam is offline
Ergoittiam is starting off with a positive reputation.
I have a 1988 Bronco II with 2.9 EFI engine, 5 speed manual,4WD, all original with 160,000 miles. For the last two months the engine stops running intermittently. Usually after waiting 5-10 minutes, it starts and runs fine, and most of the time does not give my any more problems the rest of the day. Although sometimes it will stop several times within a couple of miles and other time runs fine for over a week. It does this in wet or dry weather, cold or hot days, up hill, down hill, on curves, straight roads, after driving 2 miles or 20 miles. Once it stopped while sitting at a traffic light. I have change the fuel filter, have gas pressure at the manifold, changed the distrubitor, pickup, ICM, cap, rotor, plugs, wires, and both relays on the fender by the air filter. Also, while it ususally restarts after 5 or 10 minutes, it has let me sit for over 30 minutes several time and once for over an hour. There is no preamble to it stopping, the engine just dies and after a while it starts and runs fine. Any input would be greatly apprciated.
Old 02-14-2005, 11:38 PM
mrshorty mrshorty is offline
mrshorty is gaining momentum as a positive member of FTE.
Any codes in the computer (some causes of stalling/no start will leave codes in the computer's memory)?
Can you tell why it stalls/won't start? No spark? No fuel pressure?
Old 02-14-2005, 11:53 PM
I just got a code reader to check that, and yes there is spark and fuel pressure
Old 02-15-2005, 12:10 AM
plilikoi plilikoi is offline
plilikoi is starting off with a positive reputation.
Quote:
Gee, where did you check for a spark because it sounds as though it's likely to be the ignition module on the distributor that's got an intermittent (probably temperature-related) problem?
My BII is getting close to 160,000 miles and, in fact, I just ordered one of these modules to keep as a spare as this seems to be a really common fault at around this mileage. It's scheduled to arrive tomorrow.
Old 02-15-2005, 05:50 AM
I changed the ICM as well as the entire distributor and pickup
Old 02-15-2005, 02:53 PM
If it has spark and fuel pressure, then --
1) Is the fuel pressure correct (40 psig KOEO)?
2) Are the fuel injectors firing?
3) Is the spark at approximately the right time?
4) Is the spark getting to all/most cylinders?
5) Do the cylinders have compression?
6) Something blocking the air intake?
7) Did you get a chance to pull codes?
Old 02-16-2005, 10:37 PM
rknott rknott is offline
rknott is starting off with a positive reputation.
I had a similar problem on my 88 Bronco II, mine turned out to be the fuel pump inertia switch. This switch is located in the floor board on the passenger side. The problem wasn't the switch but the electrical connection is in a positon that someones foot can rest against it causing it to have a bad connection and thus shutting off the fuel pumps. When the engines shuts off reach over and jiggle the wires to see if it may be your problem. I replaced the switch and the wires with one from a 1987 Taurus, which is located in the trunk. I also made a sheet metal guard to keep feet off of the wiring. This solved my problem, I hope it will help you.
Old 02-17-2005, 07:29 AM
IB Tim's Avatar
IB Tim IB Tim is online now
Site Administrator
IB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputation
...Welcome rknott, to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE.
Great first post, we are pleased you have chosen the best source for Fords!
Enjoy FTE
Old 03-04-2005, 09:13 AM
Dave462 Dave462 is offline
Dave462 is starting off with a positive reputation.
The fuel pump relay could also be intermittent. All my codes were ok and the other checks were good. I finally took it to the Ford dealer when it died and had a diagnostic done on it. They found the relay was intermittent.
Please Help with engine stalling Roscoe316 6.0L Power Stroke Diesel 28 10-21-2016 07:51 PM
Long Term Stalling Issue, Recent Massive Afterfire - Blew up muffler grasfarmr73 Ford Inline Six, 200, 250, 4.9L / 300 9 10-29-2015 04:27 PM
New to the forum, my e150 is running rich and stumble off idle dz1 1968-2013 Full Size Vans 1 09-27-2012 05:07 PM
Severe Power loss when climbing hills hawkhill59 6.0L Power Stroke Diesel 5 09-08-2011 12:33 PM
'87 Bronco II starting problem ncsongster Bronco II 3 03-15-2011 07:13 PM
Tags
1986, 88, 89, bronco, days, ford, fuel, hot, ii, intermittent, pressure, problems, quits, running, shuts, stalling, stops
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
