1992 Ford Aerostar - won't start, only click...
Hi. I have an unusual problem with my wife's minivan.
Over the course of the last month, the van seemed to turn over slower and slower with each passing day. It's been cold here in Washington so I figured the battery may need to be replaced.
The very same day that I planned on purchasing a new battery, the van would not start at all, just clicked.
I purchased, and installed, a new battery. The van still would not start, just clicked.
I purchased, and installed, a new starter solenoid/relay (located on the driver-side inner panel, just right of the battery). The van still would not start, just clicked.
I purchased, and installed, a new starter motor. The van started right up and ran super...
...until I shut it off. The van WILL NOT start.
I have absolutely no idea what the problem is here and I am in dire straits.
Can anyone assist me with this problem?
ANY and ALL assistance will be greatly appreciated.
...Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE.
Stick around someone will be by shortly to answer your question.
We are pleased you have chosen the best source for Fords!
Enjoy FTE
…..See you on the boards.
Enjoy FTE
Hi LeVeque:
When you put the new battery in, did you clean the inside of the cable thingy with a wire brush? If not, try it. Also, check all the big wires going to the starter and make sure the nuts are on tight. It has happened to me before. The nuts were not on tight and you will have problem.
You also may have bought a defective starter, but the chance is pretty slim.
Welcome and good luck
jayro88
12-17-2016 12:51 PM
IDIDieselJohn
10-20-2014 09:07 PM
nalts
09-18-2010 07:15 AM
