4.0 will fit in place of the 2.9 quite easily. Not sure about the 2.8, but I half expect the 2.9 will fit in place of the 2.8 pretty easily, so the 4.0 may as well. Like Ken said, you'll need all the electronics for the 4.0. You'll also need a fuel delivery system. The mechanical fuel pump in a carbed engine only generates a couple psi fuel pressure, EFI needs ~40 psi.
you need to get all this from the same truck.
wiring harness and pcm engine and auto/stick trans.
fuel system lines,pump,tank, ac system if wanted ,front coil spring and leaf springs for the addded weight. etc.. Monty
