Project truck needed
Any of you have an old fullsize truck sittin around that you want to get rid of? Not lookin to spend much (read: I am cheap and I have to get this by the wife). I am looking to put together a pulling truck. I would prefer a 4X4 but A 2 wheel drive would be fun too. I know this is a long shot but it never hurts to ask.
were you located at? there is a 76 or 77 longbox sitting in chariton, it is an old mud drag truck but the guy quit racing, and has had it for sale for quit awhile finally sold the tires,and wheels off of it, but the truckis still sitting in his driveway with a sign in the window. If you are close you could go up,and look at it, and see what he wants, and whats there.
if you are looking in the 77 range, I hae a 3/4 2wd that the cab and clip are real good, but the box could use some attention, and a few other things... it has a 400 right now so wouldn't take much to switch to 460, and I might even be able to set you up that way. It has 4speed, but don't know the rear axle ratio..
WOW.. More response then I thought I would get. FYI.. I am in SW Iowa (work in Council Bluffs). Where is Chariton?? Year makes no difference to me. It doesn't have to be anything great. Actually it doesn't have to be a complete truck. I would just like to start collecting parts to build a pulling truck.
Fellro drop me a line of what you were thinking of for your 2wd. Thanks guys.
I've got an '80 1/2ton 4x4 chassis with tranny. I'm working on my "project" truck (see gallery ) and am pulling the cab and engine out of this other one. Don't know if I'd use it for pulling, frame looks pretty light, but it's got the tranny, transfer case and axles, could go for real cheap.
Here are a couple of topics from the Slicks (61-66) Forums.
This one discusses frame thickness and differences between years/models.
https://www.ford-trucks.com/forums/s...d.php?t=156020
This one discusses flexing issues - seems trucks weren't made to run with the front wheels off the ground?
https://www.ford-trucks.com/forums/s...ght=frame+flex
