Thump sound on driver floor when brakes applied
Originally Posted by willtim
My 2000 F250 4x4 CC V10 does the same thing(110,000 miles).Going in the local 4X4 shop this week.It has a Trailmaster leveling kit.What to look for?
With both front wheels on the ground or both in the air unbolt the links at the sway bar. Grab the link and see if there is any up/down play. If it is broken you will feel it.
mine made an occassional thump on the drivers side at slow speeds usually when turning with brakes.
i got concerned when the wheel started shuddering while braking. i thought it was warped rotors, but when i got the wheel off, i could pull up/out on the hub. i assumed it was the infamous wheel hub bearing assembly and replaced it, only to discover that it still was loose due to bad lower ball joint.
Could also be some loose exhaust pipe, muffler, or some underbody shields, or a loose running board etc.
I have had all of these at one time or another and they caused thumps or rumbles at certain times.
Best bet is to crawl around under your truck with a good light and grab and shake all the exhaust pipes, running board mounts, underbody shields, gas tank(ther is a big shield on the tank) etc. Cost of diagnosis is free. Repair is usually a bolt or hanger.
Good Luck,
Jim Henderson
Good Luck,
Jim Henderson
christyj
1997-2006 Expedition & Navigator
20
12-15-2014 11:33 AM
