Bumping up compression to about 12:1
Hi guys
I was looking at some of the older cars and some trucks out there, the new 'vette, and such, and they are/were running high compresion ratios, well into and past 11:1, up to 12.5:1 I saw. I was thinking since my truck is about 9.0:1, if I could get an extra 3 lbs. squeezed, it would extract a few good horses. Now here's the things I'm encountering: First, the old pony cars were cast iron, and could not dissipate heat well, so how did the heads hold up under such stress? Lead? Or was it reversed coolant flow? High octane was a major player, and so on. Would I need to buy anything internal to hold up, or would I be okay to run stock? Reversing coolant would be tricky, but in the end flip the impeller in the water pump, radiator, etc. I'm quite sure it can be done, so can any body help me on what to do? Thanks
Craig
Craig
Well, 12:1 is quite high, but I'd be using High octane fuel and lead substitute. It's not hard to get stronger head bolts, just get a machine shop to make bigger holes, bigger bolts, more holding power, etc. 12:1 is improbable, but possible, so I'm now in more of the 10:1 to 11:1 range, since 1 cubic foot of air/fuel squeezed is about 30 HP.
Well, easily but not legally. You can't run high squish today because of the HC emissions. Squish was a design feature of all 60's high compression engines. Basically it was an area where the piston and head had a flat space a few .010's apart that gas would squish out of creating a lot of turbulence both to keep the temperatures uniform before combustion and to spread the flame front quickly but evenly during combustion. The other biggest factor was octane. And high octane without lead is very expensive. 100LL or 110LL at the local airport would work fine for high compression at just over $2.50 a gallon except for the catalytic converter thing.
Good luck.
Good luck.
I think if you have a 97-98 shortblock and install PI heads, the compression jumps to about 10.5 to 1.
You will have to run unleaded fuel, because lead will foul the injectors. The lead was a lubricant so since all of the Modular engines have hardened valve seats, lead is not needed.
A crossflow radiator should work fine. You will need some PCM custom tuning to get the fuel table correct for the higher compression. With 10.5 to 1, you should be ok with 93 octane fuel. Use a knock sensor for safety.
Check with places like D.D.S. that make racing mod motors for more indepth info.
