Advice...new wheels...torsion bar adjustment.
A few weeks ago, I adjusted my torsion bars to help level the front of my truck. Well, this weekend, I added the wheels I had planned to. After posting a pic on another forum, a comment was made about the rideheight/tire size. Judging from the pic below, would you re-adjust the front end back down, or would you leave it where it is? Thanks.
http://members.aol.com/glassracer/outlaws
Image edited to Link by FTE
Originally Posted by triton_2002
To me, that looks like too much gap between the tire and fender. But its your truck, if you like it, who cares what others think!
What size tires are they? Would be nice if you could lower the back an inch or so.
Check out www.4wheelparts.com , they have all sorts of niffty suspension parts at fairly decent prices.
Don't worry yourself too much cause thats a good loking truck.
leave it, it looks better level, I would also recommend adding some 285/75r/16 tires to it, would make it look really beefy, thas what I did to my truck and people think I have a lift on it, check it out https://www.ford-trucks.com/user_gal...&albumid=14530
Originally Posted by 98f1504x4ohio
Leave it like it is and throw some 285/75-16 Mud Tires on it. You won't be sorry!! The tires will make it look that much better with those wheels.
It looks good, but like others said larger tires would be better. I had my torsion bars cranked up but I ended up putting them back to stock because I didn't like how the rear looked when I was hauling anything. Also the front used to bottom out on sharp drops like pot holes and things like that. Many people say that cranking the bars does not affect the ride, but I find that it does. Since I am often hauling heavy loads, I prefered the stock setting with the rear slightly higher than the front.
burtwatkins
2004 - 2008 F150
03-30-2013 07:53 AM
