1978 - 1996 Big Bronco
What is the Throttle Body??
Old 02-11-2005, 04:02 PM
poffutt's Avatar
poffutt
poffutt is offline
89 bronco 351 c6
I have heard people say to clean the Throttle body. I feel stupid because I really don't know what the throttle body is and how do you clean it. will I need gaskets etc?
Thanks
Old 02-11-2005, 04:07 PM
JBronco's Avatar
JBronco
JBronco is offline
Think of the throtle body as the "carburetor" of aTBI fuel injection system. It is what your air intake hoses connect to. It is between the air hoses and the intake manifold. It is fairly easy to remove and clean, although I clean mine on the truck (if it was very dirty I would have removed it, but it's been kept clean).
If you remove it you will need a gasket to put it back on. Not a big deal though. Also, and this is important, be sure to only use a cleaner that is safe for throttle bodies. Do not use old fashioned carburetor cleaner. It can eat away the seals in the throttle body and then the truck will run bad. They sell plenty of sprays for throttle body cleaning, they are cheap and easy to find at any auto parts store.
Old 02-11-2005, 04:13 PM
Kemicalburns's Avatar
Kemicalburns
Kemicalburns is offline
get yourself a haynes manual. its the bible for your rig and explains everything and how to work on it to.
Old 02-11-2005, 04:15 PM
poffutt's Avatar
poffutt
poffutt is offline
Thanks JBronco, Good reply, I think I know exacly what it is now and how to clean it.
Old 02-11-2005, 04:18 PM
JBronco's Avatar
JBronco
JBronco is offline
No problem!
Old 02-11-2005, 11:43 PM
poffutt's Avatar
poffutt
poffutt is offline
ok, I took off the throttle body.. What good is it to clean the TB if the whole thing it is attached to is just as dirty? you know, that thing that has EFI 5.8 on it. That thing looks like it has walls of wet gritty oil stained walls, like the TB. Do I clean both or just the TB? If I do clean both do I need to remove all of it?
Old 02-11-2005, 11:56 PM
poffutt's Avatar
poffutt
poffutt is offline
Talking
Thats good advise, If we all get a haynes we won't need this site
Old 02-12-2005, 06:15 AM
tex94F250's Avatar
tex94F250
tex94F250 is offline
Arrow Haynes & Chilton Manuals
Having a manual is a necessity for maintenance. Having interraction with other people who know and have experienced the same issues as you are experiencing is priceless. I've never seen a repsonsible post that didn't get a lot of assistance almost immediately. I have seen frustration when it's obvious that the posting party is resisting helping themselves. I personally have benefitted from the forum and use both Haynes and Chilton. BTW, they allow you to help others also.
Budman1962
2009 - 2014 F150
06-20-2016 09:23 AM
GadgetGuy22
1997 - 2003 F150
05-26-2016 12:03 PM
fordbroncodave
26
09-18-2009 09:16 PM
04markIII
06-01-2006 11:27 PM
Schlump
02-19-2003 10:37 AM
Quick Reply: What is the Throttle Body??
