For those with 460's.....
#62
10-13 MPG at Best.
Its been a while since I posted because I am in the Army and just got sent to Italy this summer. Anyways, the truck is in the garage back home waiting for some paint and a little bodywork. Prior to leaving I had switched over to a Holley 780 as well, and if I kept my foot out of it (with a T-18 4Spd) I could get between 11-13. But the engine needs some work as well. When I get back next summer and get that done I'll keep you posted as to what I did and what differance it made. Good luck with yours.
#64
My 86 F250 4x4 460, C-6, 3:55 gears, Edlebrock Performer, Holley 4160, 600 CFM. I get 9.5-10.5 MPG empty real regular. We own a 10,000# Travel Trailer, and at 65-70 MPH get 5 MPG, at 60 MPH 5.5-7.0 MPG. I have 171,000 miles on this truck engine never had heads off, I'm not sure, but I'm pretty sure, the original timing chain is still in.
#66
Originally Posted by Heavy Hauler 1
Hey Bear 45/70 where didya find the recurve items. I looked both Jegs and Summit and didn't see any listings. My rig has headers 2.5s into a 2 in 1 out 3" muffler. Im planning on upgrading the ignition system to 8mm wires and the 45,000 volt Super coil. Has anybody heard of problems with that set up? Any ideas on detonation problems, burnt pistons, valves etc. I bought this bohemoth used and dont know the particulars on the headers. They are the Tri Y type and are coated.
#67
#69
#71
Originally Posted by turbo2256
What muffler are you using?
The muffler is a 3" in and out straight thru unit, but I can't remember the brand. Will see if I can find the reciept somewhere.
#74
long drive
Just moved from Cali to Toronto.... Big box on back (raised sides of truck 3ft over bed... biggest dorkiest ghetto homemade cargo shell you have seen) got about 11.5 mpg the whole trip averaging 73 mph.... Mileage was the same going over the rockies, got better on the way down, but the puter freaked out at over 10000 feet.... not enough oxygen, so it ran super lean. Reset the check engine light and mileage went back to normal. Load in the back was light, about 2000.
#75
Hit 10.1 MPG this weekend city driving only.
