four barrel intake for a 239
does anyone know if a four barrel intake from a 292 or 272 312 will fit the 239 block ? i was told the blocks are all the same just the bore is different and the intake will fit is this true ? I would like to change the 2 barrel on my f100 to a four barrel intake . also would like to find a good set of headers to fit this block
Just to clear things up a bit (I hope), there was a 239 flathead (L-head) through 1953. In 1954, Ford came out with the 239 OHV Y-block. It sounds like you have the OHV Y-block.
I believe that the intake manifolds are interchangeable between all the Y-blocks, 239, 256, 272, 292, and 312 - but I'd sure suggest someone who knows for sure confirms that for you.
greenmachine55
08-01-2014 02:28 PM
Pilch
05-11-2004 10:31 AM
76Rangerboy
03-24-2004 02:59 AM
