DIVE-6015-A2B What is this block? - Ford Truck Enthusiasts Forums
Old 02-11-2005, 08:31 AM
jimlj jimlj is offline
jimlj has a good reputation on FTE.jimlj has a good reputation on FTE.jimlj has a good reputation on FTE.
I have a chance to purchase a rebuilt short block with this casting number on it. (d1ve-6015-a2b)I know that the d1 means it was first designed and cast in '71. I also know the rest of the casting number tell's the "REST OF THE STORY" as Paul Harvy would say.
It has some .040 over pistons with dished tops. I don't know what cam it has, but if I buy it and its not what I want I'm buying it with the plan of changing the cam. If I buy it I will rebuild my c9ve heads and put on it. Any idea if this would make a good combo or not?
Can I tell what vehicle this 460 is from with casting codes only? adam83 1973 - 1979 F-100 & Larger F-Series Trucks 41 08-20-2015 01:01 PM
Can you confirm this engine for me? onetwin 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 08-29-2007 12:48 PM
Help !! casting number on block ?? wisnowman Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 5 11-03-2001 11:18 PM
460 4 bolt update Wrencher 1973 - 1979 F-100 & Larger F-Series Trucks 3 07-14-2001 10:16 PM
Casting Numbers chopper Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 4 05-14-2001 03:06 AM
Tags
460, 6015, a2b, block, casting, d1ve, d1ve6015a2b, dive, dive6015, dive6015a2b, dive6015a2bn, dive6015aa, divea2b, ford, numbers
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
