Virginia Chapter Join Chapter, Leader:
How much lift is legal?
Old 02-10-2005, 10:10 PM
95 Snake's Avatar
95 Snake
95 Snake is offline
Anybody know how i can find the laws in Virginia? Is there laws that limit how high your truck can be or tire size? Im not going too extreme i just dont want to do the work twice... Thanks in advance!
Old 02-11-2005, 12:11 PM
Violjohn78's Avatar
Violjohn78
Violjohn78 is offline
http://leg1.state.va.us/000/reg/TOC19030.HTM#C0070
Inspection Rules and Regs..Rear though what I could section 480 says that can't have more than 3 in body lift..It's a lot of info, granted it's great right before you go into inspection if ou think you might have a trouble spot. Best bet maybe to check with a vehicle inspection station in your area.
also look under the faq here
http://www.vsp.state.va.us/safety.ht...tion%20Program
Old 02-11-2005, 08:59 PM
MonsterBroncoKid's Avatar
MonsterBroncoKid
MonsterBroncoKid is offline
va law is 33" frtom bottom most point of the bumper to the ground front and rear. no more than 3" body lift and tires cant exceed more than 1 3/4" past the wheel well or extenda flare
Old 02-11-2005, 10:43 PM
Franken-Truck's Avatar
Franken-Truck
Franken-Truck is offline
Virgnia lift heights are based on GVWR.
GVWR >4500 Max 28", 4501 - 7500 29" rear end 30", 7501 - 10000 30" rear 31"
In Virginia, Broncos are NOT considered light duty trucks, and therefore have a lift max of I believe, 22" They don't have a separate bed, and are therefore considered passenger vehicles.
Also, though most people measure from the bottom of the bumper, whoever is measuring is SUPPOSED to measure either from the bottom of the frame, or the bottom of the bumper, which ever is higher. So those people running 40's and drop-tag bumpers can still get a ticket if they get stopped by a cop who knows what he is doing
Old 02-12-2005, 01:29 AM
95 Snake's Avatar
95 Snake
95 Snake is offline
Thanks a lot, had an idea it was pretty harsh but damn! !
Ive tried calling dmv but they're clueless. I need to get the rule book before i do the work since i drive it most of the time, plus it will need to pass inspection, cheers to the commonwealth!
Old 02-12-2005, 01:33 AM
Violjohn78's Avatar
Violjohn78
That link has most of the regulations, there's A lot of info there, i' probably gone through each one but I actually like reading info..I"ll sit and read spec sheets in the back of a manual just to know the info. At least it should give you a good idea of what to look for yourself
Old 02-20-2005, 07:07 AM
Bilzhorse's Avatar
Bilzhorse
Bilzhorse is offline
Four Wheeler Mag. just did a write up in this state by state. Go to their site and search "lift laws".
