oil filter adapter
Old 03-03-2002, 07:42 AM
Marvin A's Avatar
Marvin A
Marvin A is offline
oil filter adapter
will I need this oil filter adapter when puting 429/460
into 80 f150. my frame has the hole for the filter.
Is the hole going to line up with the 429 filter strait doun?
Thanks
Old 03-04-2002, 12:32 PM
Mudman's Avatar
Mudman
Mudman is offline
oil filter adapter
You will need the adapter for the oil filter. The hole in the frame does not match the oil filter location. The filter is forward of the hole in the frame. The stock adapters they use from the factory only work on certain frames. The frame I used was a 87 F-250 that had a 351w. When I put the 460 in, The adapter would not work with the frame so I had to use an L and L adapter. The other option would be to modify your cross member before installing the motor. I already had the motor in and did not want to pull it out.
Good luck with your transplant.
Mudman
1984 F-350 460 4-spd 4x4 35"BFG
Old 03-04-2002, 10:43 PM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,679 Likes on 1,356 Posts
oil filter adapter
Lowdog
09-26-2020 09:26 PM
BarbToothaker
23
09-23-2015 09:00 AM
rustyruststang50
12-17-2014 12:34 PM
Ratsmoker
Oil & Lubrication
02-20-2002 01:46 AM
Quick Reply: oil filter adapter
