Evaporative Emission Control System Leak
check engine light came on on '01 3.0L Ranger. Pulled code PO456 (i think) "Evaporative Emission Control System Leak (small leak)"
What could cause this.
I've been trying to search for a couple of houre but I always get a message saying the system is under high load.
P0456 P0442 EVAP Control System Leak
P0456 - EVAP Control System Leak Detected (Very Small Leak)
The PCM monitors the complete EVAP control system for the presence of a very small fuel vapor leak. The system failure occurs when a fuel vapor leak from an opening as small as 0.508 mm (0.020 inch) is detected by the EVAP running loss monitor test. Possible causes are:
- Very small holes or cuts in fuel vapor hoses/tubes.
- Loose fuel vapor hose/tube connections to EVAP system components.
- EVAP system component seals leaking (refer to Possible Causes under DTC P0442).
P0442 - EVAP Control System Leak Detected (Small Leak) possible causes:
- After-market EVAP hardware (such as fuel filler cap) non-conforming to required specifications
- Small holes or cuts in fuel vapor hoses/tubes
- Canister vent solenoid stays partially open on closed command
- Damaged, cross-threaded or loosely installed fuel filler cap
- EVAP system component seals leaking (EVAP canister purge valve, fuel tank pressure sensor, canister vent solenoid (see post immediatly above), fuel vapor control valve tube assembly or fuel vapor vent valve assembly)
Originally Posted by byo71
Rockledge, where do you find those descriptions for the codes??
Look up 1995+ Ford OBD-II Diagnostic Trouble Codes (PDF)
But I had to go to my Ford Factory Manual to look up DTC P0456 since it was not set forth in the above-referenced PDF file.
The Factory Repair Manuals can be found at Helminc.com or you can check out eBay.
Where is the are these part located in the engine compartment (solenoid, fuel vapor hoses etc.) I have a friend that has an 03 ranger that we pulled the same code with my scanner. I saw that the evap solenoid was located near the brake line block. Just trying to help a friend out. BYO71 what was the final diagnosis of your issue? Thanks in advance for any help that you may be able to give.
fishon2
1997-2006 Expedition & Navigator
07-08-2009 07:08 AM
rangersvt04
1983 - 2012 Ranger & B-Series
09-16-2003 07:36 PM
