Evaporative Emission Control System Leak - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 02-10-2005, 12:31 PM
byo71 byo71 is offline
byo71 is starting off with a positive reputation.
check engine light came on on '01 3.0L Ranger. Pulled code PO456 (i think) "Evaporative Emission Control System Leak (small leak)"
What could cause this.
I've been trying to search for a couple of houre but I always get a message saying the system is under high load.
Old 02-10-2005, 12:58 PM
stackclimber stackclimber is offline
stackclimber is starting off with a positive reputation.
I had a simular problem on a B2300 and it turned out to be the fuel vapor recovery system. There is a solenoid that holds pressure in the fuel tank and mine had gone bad. It my be your gas cap too. Just a thought
Old 02-10-2005, 01:00 PM
Rockledge's Avatar
Rockledge Rockledge is offline
Rockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to behold
P0456 P0442 EVAP Control System Leak
P0456 - EVAP Control System Leak Detected (Very Small Leak)
The PCM monitors the complete EVAP control system for the presence of a very small fuel vapor leak. The system failure occurs when a fuel vapor leak from an opening as small as 0.508 mm (0.020 inch) is detected by the EVAP running loss monitor test. Possible causes are:
- Very small holes or cuts in fuel vapor hoses/tubes.
- Loose fuel vapor hose/tube connections to EVAP system components.
- EVAP system component seals leaking (refer to Possible Causes under DTC P0442).
P0442 - EVAP Control System Leak Detected (Small Leak) possible causes:
- After-market EVAP hardware (such as fuel filler cap) non-conforming to required specifications
- Small holes or cuts in fuel vapor hoses/tubes
- Canister vent solenoid stays partially open on closed command
- Damaged, cross-threaded or loosely installed fuel filler cap
- EVAP system component seals leaking (EVAP canister purge valve, fuel tank pressure sensor, canister vent solenoid (see post immediatly above), fuel vapor control valve tube assembly or fuel vapor vent valve assembly)
Old 02-10-2005, 02:26 PM
Thanks for quick responses!
Rockledge, where do you find those descriptions for the codes??
Old 02-10-2005, 08:15 PM
Rockledge's Avatar
Quote:
Most OBD-II trouble code descriptions can be found here:
Look up 1995+ Ford OBD-II Diagnostic Trouble Codes (PDF)
But I had to go to my Ford Factory Manual to look up DTC P0456 since it was not set forth in the above-referenced PDF file.
The Factory Repair Manuals can be found at Helminc.com or you can check out eBay.
Old 02-04-2011, 03:35 PM
pablocruz69 pablocruz69 is offline
pablocruz69 is starting off with a positive reputation.
Where is the are these part located in the engine compartment (solenoid, fuel vapor hoses etc.) I have a friend that has an 03 ranger that we pulled the same code with my scanner. I saw that the evap solenoid was located near the brake line block. Just trying to help a friend out. BYO71 what was the final diagnosis of your issue? Thanks in advance for any help that you may be able to give.
Old 02-04-2011, 03:40 PM
I wish I could tell you. this was a few years ago and the truck is long ago sold. I cant even remember if I ever fixed it. Sorry.
code p0455 mkotalik 1997 - 2003 F150 14 09-26-2016 11:42 AM
Trouble code P0442 on '01 F-150 5.4 WINGNUT- 1997 - 2003 F150 10 11-19-2013 04:06 PM
1999 F-150 Evaporative Emissions Control System bcoogs 1997 - 2003 F150 5 07-27-2009 05:46 PM
P0446 Evaporative Emission Control System Vent Control malfunction. fishon2 1997-2006 Expedition & Navigator 2 07-08-2009 07:08 AM
evaporative emission control system control valve? rangersvt04 Ranger & B-Series 5 09-16-2003 07:36 PM
Tags
2001, 2008, camaro, chevy, code, detected, emission, evaporative, ford, leak, ranger, small, sport, system, trac, trouble
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
