how to disable the governor - Ford Truck Enthusiasts Forums
Old 02-10-2005, 01:03 PM
fordlowrider fordlowrider is offline
fordlowrider is starting off with a positive reputation.
I Have a 2004 ford F-150 heritage 4.2L and i want more speed. i have a jetperformance and K&N intake and i stop at 99mph. if you disable the governor you will go past but if anyone knows how to i would like to know. i want to put it on the track to see the performance gained but i stop at 99 b.c of the governor. if anyone know how to disable it or fix the problem i would be so appreciative. i would like to race a rice burner and win and not shut down at 99
Old 02-10-2005, 02:01 PM
horizonhuskies horizonhuskies is offline
horizonhuskies is starting off with a positive reputation.
If you need a mile to beat a rice burner, then you should invest the money to eliminate the governor in some performance parts.
Any hoot, get a chip, Diablo, SCT, etc. are all nice chips. They can improve shift points, timing, etc. as well as raise or eliminate the govener. Good luck.
Garrett
Old 02-10-2005, 03:32 PM
true4.2 true4.2 is offline
true4.2 is starting off with a positive reputation.
Also, you cannot just disable it. If you want it gone, you must get a chip or tuner to remove it.
Old 02-10-2005, 06:30 PM
4.2manster's Avatar
4.2manster 4.2manster is offline
4.2manster is starting off with a positive reputation.
disabling the governor....
kinda sounds like giving superman kryptonite...
at least for me, im in CA
Old 02-10-2005, 09:54 PM
homer4.2's Avatar
homer4.2 homer4.2 is offline
homer4.2 is new and has a neutral reputation at this point.
Quote:
I doubt that is possible. Since ricers have an extreme top and and usually all ricers go over 150mph you'll have a hard time on a long distance strech. But I'm sure if you invest in it you could take them off the line. Do you have an ext. cab, reg. cab, long/short bed??
Old 02-10-2005, 10:12 PM
4.2manster's Avatar
dude i don't know if a civic or integra, which are the founders of rice, can hit 150.
or mabye it's been that long since i've been in the scene.
Old 02-10-2005, 11:22 PM
homer4.2's Avatar
I know neither could shut down the 5.4L, but I'm sure they could take the 4.2 and 4.6. We're only pushin' 205 ponies and the 4.6 220hp. Once those ricers hit like 50-they're gone.
Old 02-10-2005, 11:26 PM
Your funny homer. LoL. Youre right...a stock 5.4 dominates a stock manual tranny 4.2L. With your logic, and the reality of the fact that a 4.2 can easily handle a 5.4....any ricer can smoke any stock f150, reguardless of configuration.
Garrett
Old 02-10-2005, 11:29 PM
StreetCruiser StreetCruiser is offline
StreetCruiser is starting off with a positive reputation.
I beat my brothers 5.4 powerdyne blown F150 with my 4.2 when I was all bolt ons, cam, and tune. Our 4.2 rocks.
Old 02-11-2005, 10:17 AM
We do realize a 5 speed civic EX vtec 2 door coupe runs, at best, a 16.6ish. An Si (well the late 90's models) run 15.7's. The newer model Si's have more torque off the line, but too much faster. I've smoke Integras and Civics all day...well, maybe not like a GSR or Type R, but you know...
Old 02-11-2005, 04:03 PM
Black4.2 Black4.2 is offline
Black4.2 is starting off with a positive reputation.
I have beat civics and other cars of that sort also.. It's a question of what it is and how its modified(stock or otherwise). I've beaten GT v'6. Just aa quastion of what it is. NOW one of my friends had a 84 monte carlo. 350 v8 bored and stroked to a 385..over 400 ponies, with supercharger on the way..It runs 12's already.exilerating ride. Talk about whiplash. I'd like to buy a 4.2, have it bored out and bigger pistons put in. New cam, roller rockers, bigger injectors..Shall I go on?
Old 02-11-2005, 04:30 PM
Of course you can go on...Start a new thread labeled "dream 4.2L that may or may not EVER happen"
Garrett
Old 02-12-2005, 07:58 PM
Mr Clean's Avatar
Mr Clean Mr Clean is offline
Mr Clean is starting off with a positive reputation.
Quote:
Garrett
Why would that never happen? If you did just about everything Imaginably to a 4.2 V6 what kind of H.P. and torque do you think you could get out of it???
Old 02-12-2005, 10:41 PM
Quote:
So far 462 rwhp on a stock 4.2 is the max. As you can see, more power than anyone really needs.
Old 02-13-2005, 11:38 PM
Anything imaginable? Stroked, custom billet internals, balanced, ported intakes, blueprinted, gasket matched, custom turbo, heads, cam, 15 -20 psi, weight reduction, traction bars, swqay-bars, full suspension, and an expert driver? I could see 500-900 hp., similiar tq numbers, depensning on specs of the above mentioned items...plus anything I didnt think of.
Garrett
Holley 885 Carb and Governor John - NNY 1948 - 1956 F1, F100 & Larger F-Series Trucks 1 07-01-2006 08:11 AM
Ranger Governor??? policeranger Ranger & B-Series 58 03-13-2006 07:47 PM
Does activating your emergency flashers disable the speed governor? khelms_98 Expedition & Navigator 2 03-17-2004 12:55 AM
Governor Speed on a '99 Powerstroke codeman 1999 to 2016 Super Duty 4 03-02-2001 04:16 PM
Limiter/governor on E-250 van triton V8 randamonium Computer Chips & Tuners 2 12-29-2000 02:07 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
07, 2001, 2004, 2005, 42, 54, 60, disable, disabling, eliminating, f150, ford, governor, truck, v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
