Tire PSI 4 BFG Rugged Trail?
My used EX came with the OEM tires. BF Goodrich Rugged Trail 265/75/16's. The recommended tire pressure for these on the sidewall is 80psi. From the dealer they had only 45 psi in them. So I bumped 'em up to 75 psi and noticed that there was less vibration with front end steering. On the downside the ride was a bit harder, more like an F250. What are most folks running (psi) in their rugged trails? I'm thinking that the dealer keeps the tire pressures low so test drives will be cushy. I'm OK with the higher pressure, may even give me better mpg. I just don't want to wear the tires out prematurely for no reason. What do ya think?
Thanks
SG
Thanks
SG
Do the chalk test to see how it rides for YOUR truck and YOUR tires...
that's the only way to get it perfect !
ifn you can't find it with a search, I'll try....
found it...
http://www.ford-trucks.com/forums/sh...ighlight=chalk
hope thsi helps...
found it...
hope thsi helps...
johndeerefarmer
03-12-2005 11:24 AM
