95 Ranger 4.0 Idle problems - Ford Truck Enthusiasts Forums
Old 02-09-2005, 04:52 PM
FlyMX FlyMX is offline
FlyMX is starting off with a positive reputation.
My 95 ford ranger 4.0L idles rough, usually at stoplights. It only does it when the motor is completely warm, and its intermittent. Ive checked plugs, wires, AF, FF, IAC, MAF, EGR, PCV, purge solenoid, and looked closely for vacuum leaks. I checked the evaporative purge solenoid by disconnecing and plugging it from the intake manifold. Still have the same problem. Also the check engine light is on with codes
P1444 purge valve solinoid output low
and also lean bank 1 and 2.
Any help would be appreciated.
Old 02-09-2005, 09:43 PM
Rockledge's Avatar
Rockledge Rockledge is offline
Rockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to behold
DTC P1444: PURGE FLOW SENSOR LOW VOLTAGE TO PCM
Continuous Memory Diagnostic Trouble Code (DTC) P1444 indicates that Self-Test has detected a PF sensor circuit input below the minimum.
Possible causes:
- PF sensor circuit short to PWR GND.
- VPWR open circuit.
- Damaged purge flow (PF) sensor.
- Damaged PCM
So it would appear to be a bad PF sensor or a problem with the circuit.
Regarding the lean codes on both banks, those can be caused by several things, you are on the right track looking for vacuum leaks, maybe you can do the propane gas trick where you apply the gas all around the upper engine area; if there's a leak the gas will get sucked in and the idle will even out and/or increase. You should also think about re-torquing the upper and lower intake bolts, sometimes the gaskets are sources of air leaks. Change the fuel filter if it has been a while, and clean the MAF sensor:
http://www.ford-trucks.com/forums/sh...hreadid=126093
P.S. Welcome to the FTE!
Canister purge solenoid wtroger Ranger & B-Series 1 03-19-2016 10:14 AM
Truck throwing code 157 Snoopdale Ranger & B-Series 8 04-08-2012 12:18 AM
2000 ranger 4.0 code p1451 paulmdahle Ranger & B-Series 3 01-23-2009 03:57 PM
96 Ranger EVAP Purge Valve Fault dj8667 3.0L V6 4 04-18-2004 09:36 AM
Where is the purge valve on my Ranger? dbkc413 Ranger & B-Series 3 05-20-2002 08:53 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
40, 95, bank, code, explorer, ford, idle, intake, intermittent, lean, manifold, p1444, ranger, sport, surge
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
