How to remove Rotors that are rusted on Ford Expedition - Page 9 - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 11-12-2014, 12:41 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Brake Guides
Print Wikipost
  #121
Old 07-26-2012, 11:46 AM
903ASP 903ASP is offline
903ASP is starting off with a positive reputation.
Quote:
Originally Posted by crabjoe View Post
Stuck rotor here too!! I was using the bolt and nut to put pressure on the rotor, but that doesn't work.. At least on this '01 Expedition.. After reading this complete thread, I see people are cutting their rotors off. I don't have a sawzall, but I do have a 3" cutoff wheel. I'm guessing I can use it instead of a sawzall, but I need better instructions and picture would be best.
I keep seeing pie cut, when I read about the sawzall method. What am I suppose to do? Do I cut a pie slice shaped wedge from the outer rotor edge to the outer edge of the hub (The rotor would look like it had teeth like a gear) or and I just cutting the surface of the rotor, to the center then trying to crack it with a wedge?
Pictures or a youtube video on the sawzall method please.......
I used my 4 1/2" angle grinder, with a 1/16" cut-off wheel Crab. I cut straight across, and completely through the rotor. Be careful when you get to hub, so as not to cut through that. In fact you don't have to cut completely through near hub, just a deep notch. Then back at lip of rotor, cut a little pie shape ">" out of cut you just made through rotor, so wedge/chisel lip, has a place to set in. Then use a large hammer, or small sledge, and give it a few good whacks. Mine split/spread the rotor after third whack, and rotor slid right off. Good luck Crab
  #122
Old 07-27-2012, 08:36 AM
BAD RONALD BAD RONALD is offline
BAD RONALD is starting off with a positive reputation.
On my '01, I drilled three 1/4" holes about 1/8" apart in a straight line in the rotor. These were located towards the outer edge. I was careful not to go too far once through. I put the corner of a chisel in the top hole and drove it down with a ballpeen hammer. The steel is brittle enough to crack without hitting it too hard, in fact it splits easily. Note that it is not necessary to break the rotor in pieces to get it off. After it cracks, things loosen up so that it comes off as intended.
Drilling does the same thing for you that a sawzall or grinder would. If I had come across the nut and bolt method, I would have tried it first. Once those factory rotors were removed, all replacements have been generously coated with anti-seize. Never any difficulty getting them off since.
  #123
Old 07-27-2012, 11:21 AM
alloro alloro is offline
alloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to behold
That just means to do 3 cuts about 120 degrees apart, instead of just 2 cuts 180 degrees apart. With only 2 cuts, if they're not dead across from each other, the larger half will still be difficult to remove. As to not having a sawzall, you'll thank yourself if you go and get one. It doesn't have to be a $200 model, just one of the cheap $30 ones. Once you own it, you will find many good uses for it.
  #124
Old 05-05-2013, 03:26 PM
Sloshkong Sloshkong is offline
Sloshkong is starting off with a positive reputation.
Post I posted how I did it on YouTube
As mentioned by one of the users on this thread I had no luck getting off the rotor with the bolt trick method because they were so stuck on. I used an angle grinder, sawzall, Dremel tool, hammer, wd40, and bolt trick and it did the work. Go ahead and watch for yourself.
part1
part 2
part 3
  #125
Old 05-05-2013, 03:49 PM
Post Stuck rusted rotor removal
  #126
Old 08-24-2014, 12:07 PM
jerseydairyman jerseydairyman is offline
jerseydairyman is starting off with a positive reputation.
Mark your a genius,
Quote:
Originally Posted by sanman1969 View Post
2nd paragraph contains instructions:
I just wanted to add a little advice to this area. I spent 3 hours trying to remove a single rusted on rotor on my 2000 exp. Everyone says use a bigger hammer... well I did. A 3 lb hammer, 5 lb hammer and a 10 pound sledge. I also tried a can of deep creep and wd40. I also tried... heat and impact tools. Then I tried 30 minutes of searching on the internet. Finnally, I found the correct advice somewhere (I cannot find it again) so I wanted to pass the information on to the rest of you because those three hours were so #$%^&*. This is a very neat trick.
After removing the caliper and the caliper bracket you have 2 nice holes to work with to help you remove the rotor. Go buy a few 1/2 inch bolts at least 4 in long with nuts. Slide the bolt through the caliper bracket hole from the inside of the truck towards the rotor. As you slide in the bolt, place a nut on the bolt between the caliper bracket and the rotor. Hold the nut while tightening the bolt. The end of the bolt will push against the rotor and the the nut will push against the caliper bracket. Tighten the bolt as much as you can.. I mean really tight. Put on the second bolt in the other hole. After getting them both as tight as possible hit the rotor with a hammer. See if it moves at at all. Try tightening the bolts again. Hit it again. If it doesn't come off yet. Losen the bolts, turn the rotor 1/2 way try it again. On the first rotor it only took tighten the bolts once. On the second rotor it took 2 rotations of the rotor. 3 hours of pounding on the first rotor then 5 minutes with the bolt and the rotor popped off. On the second rotor it only took about 10 minutes to get it off.
Hope this helps a few of you... I wish I could have found this trick right away
~Mark
Mark thank you very much.
My 2003 F350 consumed the better part of a afternoon. It ran many years in the salted roads of Wyoming and the excessive heat of California. It took on turn of rotor with tightening bolts and came right off.
Thank you again
  #127
Old 08-24-2014, 12:16 PM
Thank you
Thank you your a genius.
  #128
Old 03-12-2015, 01:53 PM
cstanley44's Avatar
cstanley44 cstanley44 is offline
cstanley44 is gaining momentum as a positive member of FTE.
I didn't see this mentioned but I also didn't read every page, but there's a much simpler way to get these off.
There are two threaded holes in the rotor directly across from each other
Find a bolt that fits them, and thread them in. Then with a ratchet or your impact gun, screw them in and the rotor will pull off as the bolt bottoms out against the hub. Takes 10 seconds, and a lot less cursing.
A good trick Ive done is spread some anti seize compound on the rotor/hub mating surface
Makes getting it off the next time that much easier.
front caliper bolts Hank85713 6.0L Power Stroke Diesel 10 06-03-2016 02:11 AM
How to: 1995 F250 Front Disc Brake Rotor and Pad Replacement mrollings53 1987 - 1996 F150 & Larger F-Series Trucks 3 07-05-2015 04:18 PM
HOWTO - Replace front rotors on a 1999 E-250, 2 wheel ABS WVVan 1968-2013 Full Size Vans 10 05-27-2015 04:53 AM
Stuck Front Rotor 4wd trobin002 1997 - 2003 F150 9 03-29-2015 09:52 PM
help with rear rotor removal gmammakn Excursion - King of SUVs 6 05-09-2010 12:49 AM
Tags
1998, 4x4, brake, change, expedition, ford, front, lincoln, navigator, pads, removal, remove, removing, rotor, rotors, show, stubborn
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
