Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator SPONSORED BY:
  #106 (permalink)
Old 03-22-2012, 08:08 PM
903ASP 903ASP is offline
Garage is empty, add now
903ASP is starting off with a positive reputation.
Hi guys After trying to get my front 2001 Lincoln Nav rotor off a couple of days ago, with no luck, i decided to search the car/truck forums, in hopes that someone had gone through this already, and had found an easy trick to removing them. I read every post in this thread, and tried ALL tricks: gear/pulley remover, two bolts through caliper anchor holes, 3 lb. sledge, and even tried using heat from cutting torch......nada. Also tried sawzall, but it cut in about 1/2", and stopped. Thought blade dulled, so inserted new one, and it made no more head way. My last, and final attempt worked. I used my grinder with cutting wheel, cut through to hub, and just sliced into center area a little, as to not cut into hub. Then i cut a wedge in front edge of rotor, inserted large flat chisel, hit 3 times with 3 lb. sledge, rotor split apart, and old @#T&*^$# rotor slipped right off. When i did second front rotor, i by passed all of above, except cut off wheel, and had that one off in about 1/2 hr., compared to about 3 hrs. on first one. Thanks for all the tips guys, and i hope my experience, and solution, will help someone else. Good forum guys.....i registered, and book marked it
  #107 (permalink)
Old 03-23-2012, 05:51 AM
digitalshooter digitalshooter is offline
digitalshooter is starting off with a positive reputation.
I Think there are 2 key things when using the bolt method: Spraying with pb blaster and putting the wheels back on, not tight and then backing with the car on the ground and breaking them loose.
But, each will have a divverent experience and method.
  #108 (permalink)
Old 03-23-2012, 08:20 AM
kidzstang kidzstang is offline
kidzstang is starting off with a positive reputation.
I use a 16 lb. long handle sledge to get them off but then smear the hub center hole with anit-seize to make it easier next time.
Quote:
__________________
Jack
  #109 (permalink)
Old 03-23-2012, 11:25 AM
Man_tlac83's Avatar
Man_tlac83 Man_tlac83 is offline
Man_tlac83 is starting off with a positive reputation.
I may have to try that myself and see what results I get. I am ready to just skip all this and just get a new hub and rotors, since neither has been changed since I got the vehicle and god knows if the hubs are originals are not. Not sure....
__________________
98 5.4 Eddie 4x4 176K (body) & 70k (engine) she's back!
88 Stang LX 5.0 HO (stock for now)
03 Windstar LX 3.8 187k (a huge pain in the you know what )
95 Mazda Protege Dx 1.5L 5spd 222,252 miles (wrecked)
  #110 (permalink)
Old 03-23-2012, 11:32 AM
Have to admit Digital, that until i read thread, i'd never heard of the product ( PB BLASTER ). The idea of wheels on lightly, and slowly backing up/going forward surely may work, but once, having to replace lug bolts on my '77 Vette, because 4 of the 5 broke off while i was driving, i'd hate to take the chance of breaking/bending them.....lol
Something to consider in the future tho
  #111 (permalink)
Old 03-23-2012, 11:37 AM
Quote:
I'd hate to miss, and break/bend lug bolts....lol. I always never-seize everything when i put something new on, or even if i'm replacing same old part
  #112 (permalink)
Old 03-23-2012, 11:41 AM
Quote:
I'd try Digitals, or my idea first Man, hubs will surely add a lot more expense to the job. Good luck my man.......no pun intended....lol
  #113 (permalink)
Old 03-23-2012, 01:57 PM
Man_tlac83's Avatar
Oh I have. I've sprayed and waited, tightened bolts and beat on it like it stole money from my grandmother and my kids college funds. Then rotated a the rotor a little and repeated the steps. Used all kinds of different size hammers & pulleys. I didn't just myself with fire, but there is always a first time for everything.
Already need driver rotor and at this point, I rather have good new parts on the front and not go back in for a little bit.
__________________
  #114 (permalink)
Old 03-23-2012, 06:36 PM
Wink
Well, if you're intent on replacing hub/shaft, then you probably don't have worry about messin' with the rotor. If you take cotter key out, and remove nut ( not sure, but i think it's 1 1/8 socket ), you can pull rotor/hub/shaft out as 1 unit. I'm sure someone will correct me if i'm wrong, as i've never had to remove any myself. Again, good luck
  #115 (permalink)
Old 03-23-2012, 06:59 PM
Man_tlac83's Avatar
I'm not sure what size it is either, but around 3 clock pm eastern time that 's what I did. I was like screw it, it's all coming off. Especially since the hub is nicely rusted to the knuckle too . Steering Knuckle, hub and rotor are well mated to one another, a real screwed up 3some. Depending how this week goes I may take a shot at saving the knuckle. Don't want to replace all that and if I can save the hub that will be a plus as well.
__________________
  #116 (permalink)
Old 03-23-2012, 07:11 PM
Can't catch a break, can you....lol. Save the hub/shaft if you can, i'm sure they will cost a hell of a lot more than rotors. I know i've never had this much of a problem on any vehicle i've ever owned, taking off rotors Must be one of Fords "Better ideas"
  #117 (permalink)
Old 03-23-2012, 07:20 PM
Man_tlac83's Avatar
Nope I can't, luckly for this truck I love it. But love can go as fast as it can come. For what ever reason I am kind of enjoying myself. I am updating my post now if you want to see what my lower ball joint looked/looks like.
http://www.ford-trucks.com/forums/11...snapped-2.html
__________________
  #118 (permalink)
Old 03-24-2012, 09:41 AM
WOW!!! I've changed quite a few ball joints in my day, and at the worst, they were sloppy, but i've never seen one broke? What were you doing? A little "Off road rock climbing" ?........lol
  #119 (permalink)
Old 03-24-2012, 02:02 PM
Man_tlac83's Avatar
I wish, the only off roading she has seen so far is at a state park.
__________________
Tags
1998, 4x4, brake, change, expedition, ford, front, lincoln, navigator, pads, removal, remove, removing, rotor, rotors, show, stubborn
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
