Help removing plenum on 5.0 - Page 2 - Ford Truck Enthusiasts Forums
Old 02-12-2005, 10:44 AM
95 F150 95 F150 is offline
95 F150 is starting off with a positive reputation.
I felt a great sense of acomplishment when I took my upper intake off for the first time
Old 02-12-2005, 01:37 PM
JoeKramer JoeKramer is offline
JoeKramer is starting off with a positive reputation.
desertdave: The torx only have a 1 year limited warenty and are a little on the cheap side. But they are not totaly crapo cheap! They seem ok really.
95 F150: Yeah! I kinda felt that way to. Did ya notice all the tags I put on the lines in the picture! LOL I'm trying to be good about marking where stuff came from. I also took lots of pictures before I started to remove stuff. I'm thinking that it should go back togeather perfect!!!
Old 02-12-2005, 04:14 PM
Yeah Joe , taking pics and labeling certainly does help. One thing I noticed when I've worked on my engine that everything only has one place that it will plug into, all the plug in connectors have a different shape so there's really no way to plug them into the wrong spot.
P.S. don't over torque the upper intake to the lower intake, it is very easy to crack the upper intake from overtightening.
2002 Explorer Flex Plate Bolts Toored Explorer, Sport Trac, Mountaineer & Aviator 1 11-02-2012 09:01 AM
Taking out the front seat? First Ford 2004 Excursion - King of SUVs 7 07-27-2012 12:35 PM
What size Torx Driver Bit Haoleman 1999 to 2016 Super Duty 7 01-08-2011 02:33 AM
99 F350 seat torx bolts, what size socket? KBEDesigns 1999 to 2016 Super Duty 8 01-04-2010 05:43 PM
What size Torx bit for front brake caliper?? JamesDuffer 1997 - 2003 F150 1 06-11-2009 06:24 PM
Tags
302, 50, driver, extra, f150, ford, ftxel40e, long, plenum, removal, remove, removing, socket, t40, torx
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
