extended radius arms or not
I am in the process of saving up for a 6 inch susp. lift to go on my 96' 150 and i am trying to save money, but i want it to drive correctly. so i was wondering if I would be better off by buying a kit with radius arm drop brackets would do just fine or if I would be better off investing a little more and get extended arms.
Also, are the add a leafs given on kits with blocks used to replace the factory blocks
The best thing is a brand new pack of spring, but that's also the most expensive. Next in price is add-a-leaf, then blocks and shackle flip. 6" is a bit too much for blocks, so if you have the $$, stay away from it.
Better rotors, pads and shoes are fairly easy and cheap to install, but if you want more, that can be lots of work and $$$. I'd think twice before going that route.
