3208 Cat Won't Start - Ford Truck Enthusiasts Forums
Old 02-06-2005, 09:20 AM
ANDY C ANDY C is offline
ANDY C is starting off with a positive reputation.
Have A Friend With A Ford 8000 Powered By A Cat 3208 That Won't Start. It Will Fire On Ether. He Has Replaced The Fuel Filter,removed The Air Filter And Is Getting Fuel To The Injectors,plenty Of Battery Power. Any Help Would Be Appreciated. Thanks In Advance. Andy
Old 02-06-2005, 09:49 AM
IB Tim's Avatar
IB Tim IB Tim is online now
Site Administrator
IB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputation
...Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE.
.....Stick around someone will be by shortly to answer your question.
We are pleased you have chosen the best source for Fords!
Enjoy FTE ..See you on the boards.
Old 02-06-2005, 01:04 PM
Dave Sponaugle's Avatar
Dave Sponaugle Dave Sponaugle is offline
Dave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to behold
All requirements for a diesel to run have been met. It should run.
Unless some of the fuel lines have air in them from the filter change and the pressure is low at the injectors still.
Old 02-06-2005, 01:29 PM
ditch witch ditch witch is offline
ditch witch is starting off with a positive reputation.
If the engine is internally good, it has to be air base on your description. Sometimes air removal takes more patience then we're use to. Loosen the 3/4" nut at the injectors a quarter of a turn, turn the engine over until you're satisfied it's straight fuel then tighten and try again. Once it starts, if it's missing some, go back and open the nuts again one at a time to clear out the last bit of air. You'll hear the difference.
Old 02-06-2005, 09:09 PM
Thanks For The Info. Andy
Old 02-09-2005, 09:43 PM
mp492_5 mp492_5 is offline
mp492_5 is starting off with a positive reputation.
On a 3206 there was a fuel transfer pump on the left front of the block that would pump about 30 psi to injector pump. If the o rings failed the engine may idle but would not pull at 0 psi. Seems like they would take a couple days to fail completly. Presure could be checked at a plug near the primer at fuel filter.
Old 02-09-2005, 10:00 PM
Old 02-09-2005, 10:45 PM
banks7.3's Avatar
banks7.3 banks7.3 is offline
banks7.3 is starting off with a positive reputation.
check to make sure the right fuel filter was put on. we had an 8000 with the same motor a few years ago that our service company put on the wrong filter. they had started it up and checked for leaks then shut it off. the next morning we fired it up, ran fine until it used up the fuel in the filter and lines then died and refused to start. it took a few hours to figure out the problem because the filter screwed on and looked like the right one, until we checked the number. by the way, we no longer have that service company doing our maint. good luck.
Old 02-10-2005, 06:34 AM
bilder12 bilder12 is offline
bilder12 is starting off with a positive reputation.
There was also a problem with the injection pump breaking the internal shutoff. If I remember right there is an electric solenoid on the pump that works the shutoff, make sure that is working first. It is firing on ether because that is the fuel as long as you spray it in the intake, but be careful using that stuff, it WILL wash the cylinders and make the wrong things happen.
Old 02-27-2005, 07:08 PM
waynebo waynebo is offline
waynebo is starting off with a positive reputation.
I worked for a large power company and we had several trucks with 3208 cats.This a commom problem,real often.Its the retangular/square glass water seperator,should be on the passenger side firewall.replace it,put a little grease aroung the o-rings a snap the clamp back on.you will have to prime it with the primer pump,and you will have to get someone too turn it over while you bleed the injectors,even if it runs it will be rough until you bleed each injector,what a pain.There not self bleeding at all,waynebo
Old 02-27-2005, 09:31 PM
Spectramac's Avatar
Spectramac Spectramac is offline
Spectramac is gaining momentum as a positive member of FTE.Spectramac is gaining momentum as a positive member of FTE.
Thumbs up
I'm with bilder on this one. Check out that solonoid on top of the inj. pump.
Old 01-14-2011, 11:27 PM
99f350sd 99f350sd is online now
99f350sd has a good reputation on FTE.99f350sd has a good reputation on FTE.
I have the same problem..I'm going to take the solenoid off tomorrow.
Dick
Temp Sensor and Fuel Heater Sensor 1985L8000cat3208 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 0 09-28-2016 02:45 PM
Cat 3208 Engine Swap Allisfordih Large Truck 1 05-08-2016 12:29 AM
Any Cat 3208 experts? Kruse General Diesel Discussion 5 09-14-2012 10:42 PM
3208 Cat! Ky Ford fan General Diesel Discussion 4 01-07-2012 10:38 PM
477 vs Cat 3208 TheFirewoodGuy 401, 477, & 534 SD Engines 2 03-06-2007 11:50 PM
Tags
3206, 3208, 99, cat, caterpillar, engine, fuel, injector, power, problem, pump, start, steering, system, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
