Bosch Platinum +4 Spark Plugs-Any Good? - Ford Truck Enthusiasts Forums
General Automotive Discussion
Old 02-04-2005, 10:02 PM
DictatorDanny DictatorDanny is offline
DictatorDanny is starting off with a positive reputation.
Has anyone ever used the Bosch Platinum +4 Spark Plug in there F150. Are they any good or would you recomend a differnt spark plug?
Old 02-04-2005, 10:09 PM
crashnburn's Avatar
crashnburn crashnburn is offline
crashnburn is starting off with a positive reputation.
IMHO the +4's are just a gimmick, just like the splitfires. No noticable difference in performance, just a gouging on the price of them. I found std platinums work just fine.
Old 02-05-2005, 11:36 AM
captchas captchas is offline
Guest
captchas has a great reputation on FTE.captchas has a great reputation on FTE.captchas has a great reputation on FTE.captchas has a great reputation on FTE.
save our money if ford wanted a platinum plug in any motor it would be there from the factory,,many motors do and do not run correctly with them, i try and stay with oem or in the case of my fords autolite and have not had any personal problems in doing so. plus 4's are as stated above
Old 02-05-2005, 03:14 PM
IB Tim's Avatar
IB Tim IB Tim is online now
Site Administrator
IB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputation
I would have a difficult time believing a scam…. Bosh a very reputable company with millions of dollars in research and development…………and not finding an advantage to a multiple "spark" plug….they did, and they sell them.
Spark plugs with only one electrode have a tendency to foul all around the porcelain …except where the spark fires, the position and angle, of the four electrode design, creates multiple spark path, that will cause the spark to jump sideways. This has a self-cleaning effect on the center electrode. IMO they are a very good plug for many different applications…like older cars that can foul plugs. BOSH simply took the physics of firing a plug and made it to clean...pretty inventive.
When you are trying to pass emissions on older equipment it could help.
Old 02-05-2005, 05:14 PM
furball69's Avatar
furball69 furball69 is offline
furball69 has a very good reputation on FTE.furball69 has a very good reputation on FTE.furball69 has a very good reputation on FTE.
Electricity always takes the path of least resistance, so if it jumps from one electrode once it will likely always jump from the same electrode. It will not jump from multiple electrodes in a single spark.
Old 02-05-2005, 05:31 PM
IB Tim's Avatar
Site Administrator
Check out their web site.....
They explain.... their products, far better than I
Old 02-05-2005, 06:40 PM
EnviroCon EnviroCon is offline
EnviroCon has a good reputation on FTE.EnviroCon has a good reputation on FTE.EnviroCon has a good reputation on FTE.
They definately made a difference in my little Suzuki Samurai, where every little bit helps. I was able to lean the mixture on the Weber racing carb. Got maybe one or two more hp out of them. And they don't seem to foul as much as the other one's did (autolites I think.) Expensive little buggers though.
Old 02-05-2005, 09:58 PM
FBINA109 FBINA109 is offline
FBINA109 is starting off with a positive reputation.
Fbina109
I have 60,000 + miles on a set in my dual cam V-6. They perform great and have lasted very good. The best that I have read talks about there being an advantage to the four prong system in how the spark performs. I would agree go to their site and read what the engineers say. You also might check on racing forums, seems that I have seen them being used in racing vehicles. I repeat I have been very pleased with there performance and life.
Old 02-05-2005, 10:40 PM
1toptech 1toptech is offline
1toptech is starting off with a positive reputation.
OK, here is the deal. They don't generally work well in Fords. You will often notice a rougher idle, hesitation, or lower fuel eonomy. Stick with Motorcraft. As for there claims; they are trying to sell a product, do you expect them to tell you they suck?
Old 02-05-2005, 10:51 PM
Tech 1 Tech 1 is offline
Tech 1 is starting off with a positive reputation.
Multiple Electrode Plugs
Physics is Physics. Electricity follows the path of least resistance Period....
Old 02-05-2005, 10:56 PM
furball69's Avatar
OK, I went to this page: +4... quite amusing, really. Read between the lines and understand it for what they are really saying and what they want from you; your money!
All it says is exactly what I said in my previous post, along with sales jargon.
Quote:
Four ground electrodes provide multiple spark paths which allow the spark to travel the most efficient path
That's got nothing to do with the plug; that is fundamental physics. It means nothing, only one electrode path is going to be used at any given time and if one provided the path of least resistance once it likely always will.
Quote:
and deliver a longer and more powerful spark than conventional single electrode spark plugs. This offers superior burn characteristics for ultimate engine performance.
I don't buy that, A longer gap means a weaker spark unless you supe up your ignition.
Any decent platinum plug should get 50-60k mi.
My uncle swore by the splitfire plugs using the seat-of-the-pants dyno but they are the same thing as the +4's only with half the number of spark paths. Not to mention that the vehicle was just tuned up when the plugs were put in.
Old 02-05-2005, 11:41 PM
sierraben's Avatar
sierraben sierraben is offline
sierraben has a spectacular reputation.sierraben has a spectacular reputation.sierraben has a spectacular reputation.sierraben has a spectacular reputation.sierraben has a spectacular reputation.sierraben has a spectacular reputation.sierraben has a spectacular reputation.sierraben has a spectacular reputation.sierraben has a spectacular reputation.sierraben has a spectacular reputation.sierraben has a spectacular reputation.
I put a set of them in my 81 F150 4.9 and had to take them out because of rough idling. So I put back the Motorcrafts/autolites. The rough idling smoothed out. The Autolites seem to last a long time in my truck.Maybe I had a bad set. I just don't know.
Old 02-05-2005, 11:57 PM
What do you think would be the best spark plug for my 1994 f150 302 4x4?
Old 02-06-2005, 12:28 AM
Rockledge's Avatar
Rockledge Rockledge is offline
Rockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to behold
Not sure about other applications, but I know that Ford DIS/EDIS "waste spark" igntions do not like Bosch plugs of any kind. In such cases, Motorcraft or Autolite double plats, or Motorcraft's new "fine wire" (FM series), are the only way to go.
Old 02-08-2005, 09:42 PM
claw302 claw302 is offline
claw302 is starting off with a positive reputation.
i had a 99ranger supercab with the 3.0v6. at 30k miles i put the regular bosch platinums in. i gained about a mile per gallon increase. got about 25mpg on the highway and about 21mpg in the city. at 80kmiles i switched to bosch platinum +4. fuel economy there was no difference. i did have a smoother idle and better acceleration. 137kmiles those plugs were still in there and good. a platinum plug is not meant for every engine. a +4plug is not meant for every engine. sometimes you have to try a few different things until you find what works best in your vehicle and budget.
Spark Plug Gap copperjohnc 1987 - 1996 F150 & Larger F-Series Trucks 11 09-29-2011 12:02 AM
Bosch Spark Plugs garysorenson 1987 - 1996 F150 & Larger F-Series Trucks 31 07-20-2008 12:23 AM
Spark Plugs 4.9inline6 Ford Inline Six, 200, 250, 4.9L / 300 23 10-26-2005 12:07 AM
Question about Motorcraft spark plugs dwildmanj Ranger & B-Series 7 03-30-2004 01:37 PM
Debunking the Myths of Bosch Platinum Plugs Rockledge 3.0L V6 4 08-24-2003 11:40 PM
Tags
bosch, electrode, f150, ford, multi, pa, platinum, platinum4, plugs, scam, spark, splitfire, sport, stroudsburg, trac, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
