Plugged Oil Filter
You don't say what climate you are in. If you are in a warm climate, do a few quick changes using Chevron Delo 400, Mobil Delvac or Shell Rotella. They are loaded with detergents, but are heavier oil than you are probably using.
If you are in a cold climate, change a few times with Mobil Drive Clean in your favorite weight. Also, drain the oil when the engine is piping hot. That way the contaminants are churned up in the oil and will come out. Preferably drain overnight, because the crud is the last stuff to come out.
Good luck,
Doc
Good luck,
Doc
Bopper
07-12-2009 08:00 PM
ITDave
1997 - 2003 F150
15
07-12-2003 10:31 PM
