Heater Problems - Ford Truck Enthusiasts Forums
1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
Heater Problems
Old 02-04-2005, 10:58 AM
f1butcher f1butcher is offline
f1butcher is starting off with a positive reputation.
Heater Problems
Hello, I'm new to the site and look forward to posting question from time to time.
My problem lies in the Heater unit itself. I warn-up the engine and turn the heater on, for the first 5 seconds it puts out great heat ,then slowly gets cooler, till it is cold air. I have flushed the raditator and the engine block. The hoses to the heater coil is very hot. Oh, I replaced the thermostat also. A raditator shop told me that they thought it was the door flap. I did find part of a small spring clip on the floor below the heater. So I need to know is it hard to take the heater cover off and what to look for when I do? If I could find a drawing of the inter parts of the heater - that would help a bunch. Later the butcher
P.S. I have a 92 Ford Van 5.0 L
Old 02-04-2005, 12:15 PM
IB Tim's Avatar
IB Tim IB Tim is online now
Site Administrator
IB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputation
...Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE..
Check this out: http://www.ford-trucks.com/forums/sh...d.php?t=300691
We are pleased you have chosen the best source for Fords!
Enjoy FTE ..
See you on the boards.
Old 02-04-2005, 04:50 PM
tom_foreman tom_foreman is offline
tom_foreman is starting off with a positive reputation.
My first guess would be a partially blocked heater core. It gets hot but when you blow air across it it cools off. If it were the blend door, I wouldn't think it would be hot at first.
By the way did you actuallly mean you have a 5.0L in your Aerostar?
Another possibility is that the water pump is not pumping full force. What does the temp gauge read?
Old 02-04-2005, 07:18 PM
M.Herrington's Avatar
M.Herrington M.Herrington is offline
M.Herrington is starting off with a positive reputation.
Oh man, I almost started drooling when I saw the 5.0 Liter part
Old 02-07-2005, 08:49 AM
Info
Sorry, when I use the word van - it means E-150 , Aerostar is a Mini Van.
So I have a E-150 Ford Van 5.0L V8 302 . Also both hoses going to the heater coil are hot, and it does blows hot air for the first 5 seconds. f1butcher
Old 02-11-2005, 08:23 PM
forder forder is offline
forder is starting off with a positive reputation.
I suggest that install a NEW heater core.
Old 02-11-2005, 09:10 PM
ford390gashog's Avatar
ford390gashog ford390gashog is offline
ford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to all
you have a blocked heater core it results from lack of cooling system maintance
Old 02-17-2005, 12:16 PM
Thanks for the info. I believe you nailed it. In August my air stopped blowing cold air, and with not much extra money , I rolled down the windows and made it through the summer. So do I need to get the air conditioning fixed or can I just get the heater coil fixed? Thanks , Butch
Old 11-21-2008, 11:42 PM
hbronco96 hbronco96 is offline
hbronco96 is starting off with a positive reputation.
same problem with my f250. when the truck is driving the heat is great but when i sit idle for 20 min it starts to cool down. the dealer told me the heater core is partially blocked. is this true? why cant they try to unblock it instead of installing a new one? i dont know if they checked the water pump but the engine does not over heat. i kind of hear a high whistle for a few seconds when i give it gas or let off.could that be some kind of vaccum leak? and could that be causing the bad heat at idle??? Please help!!! they want $350 to replace heater core and i am not sure that is the problem. they are known for guessing at fixes.they replaced brake pads and calipers for pull to the right when hard braking only to find when it need inspection the drag link was bad. but didnt admit they were wrong about the pads and calipers!!!!!!! now the after replacing that the truck no longer pulls! PLEASE HELP
Old 11-22-2008, 12:01 PM
Heater problems
My fix was to replace heater core. The heat coming out of the vents is now 140 degrees and steady. Hope this info helps you.
Old 11-22-2008, 05:43 PM
did you have the same problem? heat was fine when driving but at idle it got cool?
Old 11-22-2008, 09:31 PM
heater problems
Yes, then in about a month or so,it slowly progressed to very little heat. My 1989 E-150 wasn`t hard to change out the heater core. Hardest part was disconnecting the heater hoses from the engine compartment. Once I got the right tool for it, the rest was pretty easy.
Old 10-19-2009, 12:41 PM
megaflex megaflex is offline
megaflex is starting off with a positive reputation.
heater
my 2000 f150 heater doesnt blow hot air my temp gauge is higher than normal my fan clutch seems to stay on more and my radiator don't seem to be circulating also my heater core hoses arent hot. My question is where do I start at fixin the problem theremostat or core. thanks, MEGAFLEX
Old 10-19-2009, 02:49 PM
gearloose1 gearloose1 is offline
gearloose1 has a good reputation on FTE.gearloose1 has a good reputation on FTE.gearloose1 has a good reputation on FTE.
Warm the engine up, stop the engine.
Then disconnect the exit side of the heater core house
Connect a length of hose into a large jug (a few gallons)
With the rad cap open (no pressure in system), measure the flow rate through the heater core... if the flow out is not greatly fast, then:
A) try back flush the heater core (disconnect other hose, feed hot water through it).
B) failing that, replace the heater core.
Before you do B), make sure that there is not a vacuum operated door that is closed or not operating properly causing no hot air to go from the core to the car interior.
Old 10-26-2009, 08:12 PM
Rod Bender's Avatar
Rod Bender Rod Bender is offline
Rod Bender is starting off with a positive reputation.
Ok,
I have a somewhat similar problem, driving the van with it just on 'vent' the temp gauge goes a little past half way. I turn on the AC, MAX and the temp drops to half way.
My question, how do you check the vacuum module that operates the heater door ?
Is there a relay for that function ? If so, where, which one is it ?
Thanks, Greg
2003 5.4L PCV line & heater hoses R&T Babich Modular V8 (4.6L, 5.4L) 1 03-01-2016 11:13 AM
Best postion for Cardboard over raditator dracond 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 23 12-11-2015 02:03 PM
JB WELD ON RADITATOR AND HOW TO FIX LOW OIL PRESSURE waystro Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 14 07-22-2013 08:34 PM
Heater hose location? JHAM 1987 - 1996 F150 & Larger F-Series Trucks 1 01-13-2011 10:12 PM
Heater Core failure fp_5 1973 - 1979 F-100 & Larger F-Series Trucks 7 11-15-2005 09:32 PM
Tags
150, 1989, 93, brakes, control, core, f250, ford, forum, front, heater, problems, replacing, valve, van, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
