As has been noted, just changing tire brands or air pressure can "affect your mileage".
Quote:
Originally Posted by Adventure
Change all the gears and tires sizes you want, they really don't affect your mileage one bit!
As for gas mileage, changing tire size will do nothing
tire size and gear ratios don't come into the equation
Of course a 3.31 or 3.55 axle will return better MPG than a 4.10.
Note that published tire sizes still aren't always directly comparable & to find the true diameter/circumference you need to measure.
IMO most of the gas is burned just punching the hole in the air. I've experienced only minor MPG costs from loads. Changes between head winds & tail winds have made more of a difference in MPG than loads.
I wonder if anyone has attempted a High MPG conversion? Curious what the potential is for a lowered, tall skinny tired, tall geared, air effects Econoline?
I'm still impressed by Sprinter's 5 cylinder turbo diesel capability of reliable mileage in the mid, even upper, 20's MPG range. IMO there is no valid reason why FORD can't do better & produce an E-Series van that returns nearly 30 MPG. A stout 4 cylinder turbo diesel, tall gearing & more efficient packaging could turn the "E" into an environmentally friendly green machine.
