5.4 Cylinder heads
5.4 Cylinder heads
I have a 2001 F150 with the #3 spark plug blown out. The mechanic recommended a fix from ford. That would cost 2500. I have since found used cylinder heads for less money and the mechanic recommended changing both sides if I did this. For an additional 3 hours labor.
My question would be that since the 2003 heads fixed this problem. Would I be able to change these heads to a 2003 without any significant changes to the other motor parts? I tried to go to a link provided earlier in this forum on comcast but it was canceled.
...Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE.
Stick around someone will be by shortly to answer your question.
We are pleased you have chosen the best source for Fords!
Enjoy FTE …..See you on the boards.
I dont have any experience with this, but from what I have read about the problem I think I would use the Big-Sert repair on my existing heads before I replaced them with other new or used heads. If I went to the trouble of pulling the heads, I would do all eight plug holes with these steel inserts. Or, you might try repairing the the blown hole without pulling the head.
faq:
http://www.timesert.com/FORD%20TRITO...G%20REPAIR.htm
Instructions:
http://www.timesert.com/Triton-repair.html
faq:
Instructions:
