Remanufactured 302
i say do a 351w swap , you will get better towing performance out of it and its a strait over swap for the most part. your mpg wont be about the same to. I did this 2yrs ago and has been a great upgrade to my bronco. i found a complete 5.8 motor from a wrecking yard for 800. it had 80k miles on it and 170compression on all cylinders. you just reuse your 302 engine harness , and can also use the accessory's on the 5.8 as well.
what all needs to be changed
so what all will i need to change for the 351w to work correctly with the current trany. I believe its a AOD is the corrrect code. can i use the same wire harness. is there anything major what i will have to change out basically. not worring about fuel injectors, belt, pullys etc. thats all minor. sorry for all the questions and thanks for all the answers..do you know of any place that sells remanufactured motors? (jaspers)?
scott
scott
Here's one at www.powerpro200.com just click on longblocks link under the gasoline engines. These motors are warrantied for 5yr, 100,000 mi.
Size Cyl Year Vin Description Part # Price Core
<TABLE style="WIDTH: 517px; HEIGHT: 58px" borderColorDark=#666666 width=517 borderColorLight=#cccccc border=1><TBODY><TR><TD width="9%" height=32>
</TD><TD width="8%" height=32><!--mstheme-->
</TD><TD width="9%" bgColor=#b3d9ff height=32><!--mstheme-->
</TD><TD width="9%" height=32><!--mstheme-->
</TD><TD width="35%" height=32><!--mstheme-->
</TD><TD width="13%" height=32><!--mstheme-->
Here's another one @ www.ford-rebuilt-engines.com These motors are warrantied 7 yrs, 70,000 mi prorated.
<TABLE height=10 cellSpacing=1 width="90%" align=center border=1><TBODY><TR vAlign=top align=left height=10><TD colSpan=5>FORD / MERCURY
</TD></TR><TR vAlign=top align=left height=10><TD>Catalog No.
</TD><TD>FOR-302RLB-2
</TD><TD>Vehicle
</TD><TD colSpan=2>FORD 92-93 8 cyl
</TD></TR><TR vAlign=top align=left height=10><TD>Engine Size
</TD><TD>302/5.0
</TD><TD>Engine Type
</TD><TD colSpan=2>
</TD><TD colSpan=4><TABLE height=10 cellSpacing=1 align=left border=0><TBODY><TR vAlign=top align=left height=10><TD>FI, Roller cam, Knock Sensor, Truck & Van only.
</TD></TR></TBODY></TABLE>
</TD></TR><TR vAlign=top align=left height=10><TD>VIN Codes
</TD><TD>N
</TD><TD>Block Casting
</TD><TD colSpan=2>
</TD></TR><TR vAlign=top align=left height=10><TD>Crank Casting
</TD><TD>
</TD><TD>Head Casting
</TD><TD colSpan=2>
</TD></TR><TR vAlign=top align=left height=10><TD>Engine Options
</TD><TD colSpan=4>Additional performance options are available for most engines. To request additional options, simply type 'I'd like additional options' on the comment field located on the order form and we'll contact you with the list of options available for this engine before we build your engine.
</TD></TR><TR vAlign=top align=left height=10><TD>NET Price
</TD><TD>US$ 1253.00
</TD><TD>Core Deposit*
</TD><TD colSpan=2>$150.00
302/5.0<!--mstheme-->
V8<!--mstheme-->
92-93<!--mstheme-->
N<!--mstheme-->
Fl, Roller Cam, Knock Sensor, Truck & Van Only, For Car use DFH2<!--mstheme-->
DFH1<!--mstheme-->
$1,595<!--mstheme-->
$260
</TD></TR></TBODY></TABLE>Here's another one @ www.ford-rebuilt-engines.com These motors are warrantied 7 yrs, 70,000 mi prorated.
</TD><TD>Vehicle
</TD><TD>302/5.0
</TD><TD colSpan=2>
V-8
</TD></TR><TR vAlign=top align=left height=10><TD>Description</TD><TD colSpan=4><TABLE height=10 cellSpacing=1 align=left border=0><TBODY><TR vAlign=top align=left height=10><TD>FI, Roller cam, Knock Sensor, Truck & Van only.
</TD><TD>N
</TD><TD colSpan=2>
</TD><TD>
</TD><TD colSpan=2>
scott
scott
if you can get a complete motor (oilpan to upper intake) it will make this so easy . but if you start with just a bare longblock then there are a few extra things you would need. like upper/lower intake, Distributor & oilpan. now most those things can be found at your local wreckingyard for cheap im sure. but i found the complete setup was just way easier. especially if it has low miles.
keep the questions coming , because once you get started it really starts coming together. I did this by myself in my driveway
greentruck72
04-01-2015 05:39 PM
meck1
08-23-2005 02:00 PM
cmil1
1997-2006 Expedition & Navigator
10-21-2004 09:13 PM
Pastmaster
04-15-2003 08:28 PM
