Is dealer jerking me around?
I have an 04 F150 4.6 with 5,000 miles. I took the truck in to get my hood repainted due to a small crack in the paint. They fixed this without any problems (I am hoping so because I got the truck back today and it is raining so I really can't tell). When I took it in I noticed that the outer edges of the front tires are starting to wear a little. It is not bad but you can tell there is a little wear with I thought was unusual with so low of miles. The dealer told me that the front end of the truck was aligned perfect and the camber was set right. He said you are supposed to rotate the tires every 5,000 miles. He said his 04 F150 does the exact same thing. This doesn't seem right to me because if this is the case then I better plan on buying tires a lot which is not an option I am going to take.
The best way to increase tire life is what has already been said, check the air pressure regularly and rotate the tires on a 5000-7000 miles interval. I usually change my tires at around 40,000 miles with about 3-4/32 of tread left and I always buy tires in the fall, nice to have new tires in the snow.
