71 F100 swaybars and front springs - Ford Truck Enthusiasts Forums
Old 02-01-2005, 06:07 PM
65comet 65comet is offline
65comet is starting off with a positive reputation.
I have found 1" front sway bars for this truck but really want a bigger one.
1 1/4" would be nice. I can't find front springs other than stock, I'm looking for stiffer performance springs. Does any one know sources for these? How about sway bars off other rigs that will fit here? How do the sway bars hook up to the front beams? I need sources. Thanks.
Old 02-01-2005, 07:10 PM
71100 71100 is offline
71100 is starting off with a positive reputation.
Check Bone Yard 67
Old 02-01-2005, 08:03 PM
"Beemer Nut" "Beemer Nut" is offline
"Beemer Nut" has a good reputation on FTE."Beemer Nut" has a good reputation on FTE."Beemer Nut" has a good reputation on FTE.
sway bars, springs
Hey 65 Comet, there was a bar years ago that went between the radius rods also look at the 1 ton trucks, the bar mounts on the frame like GM products and a strut mounts next to the lower shock mounts. Later Ford F250's had a higher top spring mounting bracket, 68-69 had the lower tower with a shorter spring. On my old 69, then 68 CS I installed springs that had a wire diameter of .712", empty driving the front end pushed. Check on different spring thickness as well as changing the top spring tower, tall or short to fit your needs.
Carl....=o&o>....
Old 02-01-2005, 09:31 PM
whd507 whd507 is offline
whd507 is starting off with a positive reputation.
try a spring from heavier package/engine.
the 73-79 sway bars attached to brackets wedged between the I-beam and spring/strut arm.
Old 02-02-2005, 07:41 AM
4Cammer72 4Cammer72 is offline
4Cammer72 is starting off with a positive reputation.
check performanceswaybar.com
Old 02-02-2005, 03:56 PM
I'm not sure but I think I have the heaviest front springs. The truck is a 390 truck, ( now a 428 ) with a.c., p.s., p.b. The only downfall is the C-6, gimme the 4 spd.
What years 1 ton trucks would be donors?
I want to make the truck my daily driver work truck and am seriously considering swapping the 302, C-4 setup from my 65 comet in there. That comet needs that 428 hooked up to a 4 or 5 spd and a straight axle A/FX look. It's all on paper right now, but with one project about done, I'll be ready to start on that.
No one knows of performance springs made for these? You'd think somebody has to make them. Seams they make so much more stuff for the chebbies.
Old 02-02-2005, 09:13 PM
1 ton sway bar
Years ago I pulled a bar off a 73 1 ton truck. This had the bushings on the frame like GM's with struts that mounted on the I beam brackets.
Carl....=o&o>....
Old 02-03-2005, 08:00 AM
Six Niner Six Niner is offline
Six Niner is starting off with a positive reputation.
65 comet have you tried the vendors on this site? if they dont list any springs i know LMC truck has a 2" drop spring and leaf spring to match. good luck on the A/FXer man that sounds sweet, im a big fan myself.
Old 02-03-2005, 09:42 AM
I'll try the LMC guys, a 2" drop would be perfect. If I understand Carl right, the 68-69 ( what about 67? ) springs are shorter than 70 - 72. By how much? That could be a nice solution. I don't have them all lined up here to measure. It's those damn little details that mess a guy up everytime. I need to go down to a boneyard and spend some time measuring stuff.
Carl, what makes the front end push that you mentioned, too stiff spring or not enough?
Old 02-03-2005, 11:32 AM
higher spring tower
On the later trucks the top spring tower is higher and the springs are longer like 2 1/2 to 3 inches. The springs will fit the low tower but you camber will be way off and the front will look like a 4 x 4. Front end push like I stated would be understeer, your going straight with the wheels turned. With a empty truck the outside front tire is loaded beyond the tires traction.
Carl....=o&o>....
Sources for front sway bar after D60 SAS? LeoJr 1987 - 1996 F150 & Larger F-Series Trucks 7 09-10-2015 07:54 AM
springs and sway bar Brian Skinner Aerostar 12 02-06-2015 05:44 PM
Front sway bar lets7777 1948 - 1956 F1, F100 & Larger F-Series Trucks 8 02-27-2012 09:32 PM
where to get quality 2wd sway bar? notyettoday 1973 - 1979 F-100 & Larger F-Series Trucks 2 07-13-2008 11:06 PM
Sway Bars 71mustang Brakes, Steering, Suspension, Tires, & Wheels 9 02-24-2002 04:19 PM
Tags
1967, 71, bars, f100, ford, front, sway, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
