Best mpg from inline 6? - Ford Truck Enthusiasts Forums
Old 02-01-2005, 05:31 PM
Ol' Ranger Ol' Ranger is offline
Ol' Ranger is starting off with a positive reputation.
Just wanted to know what kind of gas mileage I could generally get from a 1992,standard cab, long bed inline 6 (300ci.)?
I've always had Rangers, 4cyl&6cyl and been happy with 20-25 mpg.
I had a 89 F-150 351that got all of about 11mpg,on a good day, without wind.
I didn't know if there would be much difference between the 6cyl. & 8cyl.?
Thanks for any info.
Ol' Ranger
Old 02-01-2005, 07:54 PM
the peppermint the peppermint is offline
the peppermint is starting off with a positive reputation.
efi gets a lot better gas mileage than my old 84 carbed setup, but i can get 14 city and 16 highway with 30 inch tires and a 3.08 rear end
Old 02-01-2005, 07:57 PM
dieselsaurus dieselsaurus is offline
dieselsaurus is starting off with a positive reputation.
This will depend greatly on the gearing, tranny and skinny pedal treatment. I have an '89 F150 4spd, 300, 3.08, 4x4. It gets an easy 17+ around town and through the country side - with moderate applications of acceleration. I also have an '89 F350 C6, 7.3 diesel, 3.55, 2wd. It gets around 16+. It doesn't matter if I go 35 or 65, empty of towing 10k pounds. Your 300 is just one variable in the greater formula. Most of these vehicles (when in proper tune) are good for mid to high teens. IMHO.
Old 02-01-2005, 09:25 PM
mattri mattri is offline
mattri is starting off with a positive reputation.
I got about 18 in an 82 Bronco, all stock with a 4spd, very "broken in".
Old 02-01-2005, 11:12 PM
Project Lazarus Project Lazarus is offline
Project Lazarus is starting off with a positive reputation.
I've never seen a common MPG # for 300s. I've seen them greatly vary, even for stock motors. For instance, my motor is all stock except for my exhaust. With 32" tires, 4.10s, and M5OD manual overdrive transmission, I'm averaging 7-8mpg mixed highway/city taking it easy on the pedal. When it had 31" tires, stock 3.08 gears, stock exhaust and same transmission, I think the best mileage I got was 12mpg, also mixed highway/city. You just can't tell with these motors.
Old 02-02-2005, 04:36 PM
Broncocustom1219 Broncocustom1219 is offline
Broncocustom1219 is starting off with a positive reputation.
I have a 1990 with 3" Gibson exaust a high flow cat, tb spacer and a K&N air filter and 33" tires with a stock rear and im getting 16-17 on the highway and 10-12 in the city. I guess for what i have on it im doing ok?
Old 02-02-2005, 07:29 PM
project supercab's Avatar
project supercab project supercab is offline
project supercab is starting off with a positive reputation.
Im running a 77 supercab 4x4 4.10 gear 35" tire 4 speed with a 4barrel and split exhaust manifolds 10-15 MPG and thats usually pounding it!!!
Old 02-03-2005, 01:59 AM
sierraben's Avatar
sierraben sierraben is offline
sierraben has a spectacular reputation.sierraben has a spectacular reputation.sierraben has a spectacular reputation.sierraben has a spectacular reputation.sierraben has a spectacular reputation.sierraben has a spectacular reputation.sierraben has a spectacular reputation.sierraben has a spectacular reputation.sierraben has a spectacular reputation.sierraben has a spectacular reputation.sierraben has a spectacular reputation.
I USED to average 20 mpg highway, with 23 being the best I got with a 1981 F150, 4.9L, T-18 trans, 2:75 rear end ratio and 215-75R15 maypop tires. I said used to. Now it's more like 17-18 hiway. That's because I changed the ratio to 3:50, put on a set Michelin tires (9.50 R15) on American Mag 10 spoke Vectors. Also threw in an Advanced Adapters Ranger Torq Splitter (27% o.d.). You can say my truck has 8 foward and 2 reverse speeds.
Old 02-03-2005, 01:03 PM
Sgt Wonderful's Avatar
Sgt Wonderful Sgt Wonderful is offline
Sgt Wonderful is gaining momentum as a positive member of FTE.
I get about 12 on a rainy day. Even after a fresh tune-up. My old 301 pontiac gets in the 20's. Both are 79 models.
Old 02-03-2005, 02:34 PM
wickymustang wickymustang is offline
wickymustang is starting off with a positive reputation.
My 95 shortbox regular cab, with the M5OD and 3.55 rear gets 20 or a little better (24 or so) on the highway and about 14-16 in town. That is with a bug deflector, moon visor, and open box.
Old 02-03-2005, 03:12 PM
Roushians's Avatar
Roushians Roushians is offline
Roushians is starting off with a positive reputation.
Quote:
Awesome!! I really, really hope my 96 RC/LB with the M5OD gets the same as yours does (It hasn't arrived yet - shipped from KY!)
Old 02-04-2005, 12:53 AM
'961506 '961506 is offline
'961506 is starting off with a positive reputation.
How does that work??? MY bro had a '96 with no added wind resistance. 100% stock w/K&N filter and he gets 17 at best with recent tune-up and synthetic oil. He has the M5OD and 3.55 with 70/30 HWY/city mix.
Old 02-04-2005, 12:54 AM
he also hardly revvs past 2200-2300 RPM too, what do you shift at?
Old 02-04-2005, 10:01 AM
Generally I shift at 2k, sometimes higher if I need to get moving in a hurry. I have a catback exhaust, paper air filter, tune up with plugs/wires/rotor/cap, castrol syntec blend oil, QS synthetic ATF, fresh gear oil in the rear end. I don't floor it to start off and I shift smart according to conidtions. Learned to drive stick from my dad, retired long haul trucker and have done a little semi driving myself.
Old 02-04-2005, 03:26 PM
Red2003XLT Red2003XLT is offline
Red2003XLT is starting off with a positive reputation.
You guys that are getting less than stellar mileage. What is your cruising rpm?
60,000 transmission fluid change? awq134 2009 - 2014 F150 6 12-25-2014 02:50 PM
My new ol' girl... Ford4dog 1987 - 1996 F150 & Larger F-Series Trucks 15 12-17-2012 07:47 PM
Camshaft???? RANGER589 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 18 06-03-2011 11:03 AM
Need Pro Techs HELP Please....(LONG) lorenambrose 3.0L V6 11 06-26-2010 08:53 AM
Rear ends dustin.murdock 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 06-21-2010 12:09 AM
Tags
2005, 240, 46v8, chapman14219yahoocom, ends, f150, ford, im, inline, line, motor, mpg, rear, truck, van
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
