1992 f-150 4-Low
1992 f-150 4-Low
Im wondering how to engage the 4-low on my four wheel drive. It is push button and to engage four high I just push the button and on my way I go. I tried to push the 4-Low button and nothing. It wont even light up the button and it doesnt feel like im even in four wheel drive. Its there a certain way to do this. Help!
I have the same problem as you. I tried it in neutral and park and it still does not want to shift. Not that I have ever needed to use 4 lo, but it would be nice to have to working in case I ever need it. All I know is that you can not be moving and the truck needs to be in neutral or park.
What Now?
I tried putting it in park, neutral, drive and had foot on the brake all the time. nothing. I wonder if it may be the motor on the transfer case. if not can the switch go bad on just 4-low? Im baffled. I may try and take the little motor off the side of the transfercase, take it apart clean and lube it. Guess its worth a try unless anyone else can shoot me in another direction. Thanks folks. Ryan
okay,l pulled off the transfer case motor and cleaned, lubed and reassembled. Note I had to make 4 gaskets to put it back together and mounting it back onto the transfer case. I did discover that the sequence to getting the 4-low to activate is this: first put into 4-high then shift to neutral with foot on brake press 4-low button. and thats it. Not sure if I wasted my time on the motor but I know it did not hurt. So hope my delimma will help someone else with this. Thanks Ryan.
