4.0 carb/ duraspark conversion
I think it is possible to carb a 4.0 and run a duraspark ignition on it as well. If the oil pump drive shaft is the same on the 4.0 as the distributor shaft on the 2.8, you should be able to run the 4.0 dist. gear on the 2.8 dist. and put it in the 4.0. Most likely it wont be the same as the 2.8 but rather the 2.9 which in this case, will not work, Ive tried and I scrapped a 2.8 duraspark because of it.
If it works, than that takes care of the ignition. I think it would be fairly easy to fab up a new plenum with mounting for a few weber side-drafts or even hash one out for a holley or so. I think the 4.0 could be a healthy little carbed engine if built right with bigger valves/port job, huge cam, and hi compression. Its way simpler to run those upgrades on a carberated engine. Im already planning a way for a carb/duraspark conversion on a 2.9.
reamer
07-09-2017 12:08 PM
MrFord619
01-26-2017 07:06 AM
xphr8r
06-22-2016 05:16 AM
84chateau
05-18-2016 09:52 AM
BBF250
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
02-09-2007 01:01 AM
