You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
I thought they stopped putting them in these trucks in 87 but I could be wrong, my Dad has an 85 with one and it could tow anything ya want it was just a slug off the line. I am thinking about looking for one, so as long as it checks out good I would suggest it.
__________________
2007 F350 C/C XLT 6.0 4x4
2005 F150 Super Crew Lariat 4x4
1984 F150 XLT 351w and C6 is Chromed to the Nutz!
The 6.9 is a great engine. Plenty of power, and it's pretty economical too. Should get between 16 and 20 mpg.
The early 6.9's pre 85 had head gasket problems. Apparently from improper torque at the factory. In 1986 to 1988 the 6.9's had soft rings. This lead to premature wear and use of oil. check the tail pipe. If it's thick with soot you have an oil burner. Another way to check is to start it cold. If you get a cloud of blue the rings are likely bad. Rev it up after it warms up...if you get a blue cloud then it's burning oil.
If it is burning oil the engine will still run good if the fuel system is good. Diesels burn oil real well. You will get mileage off the oil, but it's expensive fuel at a buck a quart!
I have a 6.9 in my truck with 300,000 miles on it and it's still running strong. But it is using oil. Thanks to Ford using soft rings. I do hear that the properly rebuilt 6.9's were using better rings, so if the motor is a second motor with 85,000 on it it has a lot of life left. A diesel motor should run for 500,000 miles.
I had a 86 F 250 with the 6.9 and it was a great truck. If you run 3 inch exhaust, single pipe you will get 22 24 mpg. The only think i had go wrong was the water seperator? i dont no nuthin bout them things. I just routed around it with some fuel line.
I wouldnt say 22-24 mpg....maybe 15-18 depending how its geared. my '85 gets avg. 12 mpg.
'85^ 6.9 = Best ford diesel ever!!!!! IMO
__________________ 1985 F-350 6.9L 2x4
Flatbed, DRW, 4.10's, ZF-5 swap, buckets, push button GP's, 103k miles 1989 F-350 7.3L 4x4
Kingpin D.60, Srw, 4.10 l/s, push button GP's, ex-tree service truck, dumped utility bed for the bed off an '89 . Soon to get paint with the idea of yellow and black "boss 302" graphics....but it won't say "boss 302"
If its a true 88 then its a 7.3 IDI, which is 95% the same motor. There are a couple of slight differences with the 6.9, but they are so tiny they aren't worth mentioning.
They are great motors, I have 250K on mine and its been well abused in its life.
They can pull anything if your patient, you won't be the first to top the mountain, but you'll always top it.
Depending on what gears your look at 12 mpg (T19 or C6 and 4.10's) to 20 mpg (ZF 5 or E4OD with 3.55's)
__________________
1999 F250 7.3 ZF6 4x4 3.73's 200k miles
1997 F250 7.3 ZF5 2wd 4.10 430K miles Dr. Ron Paul 2012!!
HA. It is.....I hardly look at the dates, I just read the posts.
But that blank post looked suspicious.
