Need a running Y in S. California
Hi all,
Looking for a running Y block in or near southern California. The year and size doesn't matter, as long as it is a runner, is a Y block and is relatively inexpensive.. so even the lowest compression 2 barrel Y will do.....
Would appreciate any leads you might have. I'm trying to help out a fellow y-block'r that needs to get his daily driver back on the road while his engine gets repaired (might be a long while)....
