400 crank in a 351C?
I've got a vehicle with a 400 engine, and a 3spd FMX transmission. I want overdrive, but they don't make a big-block compatable overdrive transmisssion small enough to fit in my car. So I'm wondering, since a 400 is essentially a 351M with a bigger stroke, any reason the 400 crankshaft won't bolt into the 351C and give me a 400 engine that will accept an AOD transmission?
well the first problem with what you want to do is the 351c uses 2.5" mains, and the 400 uses a 3" main. Now they have been turned down to make that work, and I won't say it is a good idea or not, but by the time you pay for the machine work to turn the mains down, figure out the rods, and pistons for that combo etc, you might be better off buying a 393 stroker kit for the cleve if that is the way you want to go
derherr65
19
08-23-2019 06:29 PM
fiftyfordfloored
30
04-09-2007 07:19 AM
swamphog
10-30-2006 01:02 PM
