Fuel Injector Cleaners
I think we can all agree that whether you use dino or synthetic, change every 3k or do a UOA to set up a legitimate extended interval, or whatever system you use, we all know the importance of changing oil at the right time.
My question is - if we change oil at appropriate intervals, is there any real benefit to using fuel injector cleaners on a well maintained engine?
If so, does anyone know of any good injector cleaners that don't use kerosene?
I use an injector cleaner once in a while. Don't know if it really does much good, but can't hurt much either. I don't have one that I really like over others. Have used Pyroil, Stp, Gumout or Marvel mystery oil. I never really paid attention to whether they have kerosene in them or not until JET FUEL started being advertized by STP. Since that has been on their bottle I haven't bought any of their stuff. If they are stupid enough to put that on there, I am smart enough not to trust their product. What harm could kerosene do anyway?
I will, on occasion, buy a bottle of the higher-end total fuel system cleaner products. They are about $5 for a bottle.
I honestly don't know if they make a big difference. I think not only of the injectors but also of the valves, etc that might have buildup. I have never seemed to suffer from problems that one might attribute to clogged injectors or bad deposit build up. I do not say this is a result of using the occasional bottle of fuel system cleaner. I might have had the same result if I had never used a drop.
I buy major brand 87 octane gas and assume the detergents added to today's gas do a decent job of keeping the injectors, etc. clean.
I'd guess I've bought 4 or 5 bottles of the stuff in the 156,000 miles I have on my 2000. If I have wasted money, in the whole scheme of things, it hasn't been that much.
Unlike some "just pour it in" products, I don't know of any problems that might come as a result of a bottle of fuel system cleaner.
Berrymans Chemtool B-12 is a toluene and acetone based injector cleaner. Toluene is used as an anti-knock agent in some gas formulations. Acetone is a hot (meaning it evaporates FAST) keytone and works great for cleaning the system. It is also a plasticizer and as such should be used in small amounts and only as an occasional cleaner. I use acetone purchased from a home center and add 6 oz to a full tank of gas, run the tank thru the engine and then change the oil. It's tempting to run it in every tank as it is also 150 octane and you will notice the difference in performance. But don't run it full time as it will eventually do damage to the plastic parts in the fuel delivery system.
I too have used Berrymen's Chemtool B-12 FI cleaner in my Aerostar van, on occasion. However, I always try and use a nearby brand name gasoline, that is always busy (however, I go there either very early in the morning or late at night. Long lines, with vehicles pulling in left, right, front, back, sideways etc. are annoying and a waste of time!) I also use some isophyol dry gas, once a month, every month, year around. I realize here in northern California it's not necessary, but old habits growing up in NE OH are hard to break. Also, a product called Sea Foam is suppose to be excellent for maintaining injectors. Auto Zone, in my area, is now stocking it. Anybody else famalier, or using Sea Foam?
Yep, I use it regularly. I usually let the engine ingest about 1/3 of a can through the vacuum line to the brake booster. Then I put the rest in the tank, usually with the tank at 1/2 or less. Let the engine sit for about 30 min., then start it up, it'll smoke like it's on fire. Rev it up, then drive it for about 5 miles. Don't spare the ponies. It'll smooth out the idle, and it's supposed to clean the carbon out of the cylinder's.
I do the same thing right before a oil change.
All I know is, that it is friggin cool leaving that 2 mile stretch of white smoke behind my F-150 with dual exhaust!!!
I almost wish I had the courage to make a pass by some sort of "Save the Earth" march or something!!
Have you measured a noticeable gain in mpg by using 6 oz. of Acetone???
My intial thoughs would be that 6 oz of 150 octane Acetone, would be totally insignificant in a 25 gallon tank of 87 octane gas.
Would it be safer to run 3 oz on a regular basis??
I've noticed that a lot of posters on BITOG really swear by Fuel Power and Lube Control products...any comments??
http://lubecontrol.com/
Fandini
06-15-2012 04:18 PM
tseekins
EcoBoost (all engine sizes)
07-08-2011 12:28 PM
dunbar15
08-23-2005 07:07 AM
