mass air meters
Check engine light
The check engine light was the most significant difference that I noticed after installing a Granatelli Mass Air Flow Sensor into my 2001 5.4l. I already did the K&N FIPK and Flowmaster exhaust aftermarket upgrades which got me somewhat aroused. That was money well spent. I was disappointed with the new mass airflow sensor . The check engine light came on regularly after heavy throttle usage. My latest upgrade was a Hypertech power programmer. Tuned for premium gas this Triton is quite impressive. The chk eng. light now remains off.
I plan on installing a throttle body spacer next.
it my be just me, but i wouldn;t get one. you would be better off to buy a larger thottle body. a little more money up front, but it will save you in the long run. i am pulling my tb spacer off for a larger tb. because the spacer will not work with a larger tb it is matched to the stock tb.
furrby
furrby
Originally Posted by DeckedoutF150
i hear the new MAF will give you up to another 17hp at the rear wheels. i would also add the 75mm therottle body.
Put your truck on the dyno and prove us all wrong, but you aren't going to get anything noticable out of a maf upgrade until you start making big horsepower and pegging the stock maf.
I've got a MAC 75mm TB and it seems to work ok...had a problem with a high idle rpm and it still seems slightly elevated. I'd try a BBK model...maybe the better build quality will help. You'll also need to port out the TB elbow to match...takes only an hour maybe with a die grinder and some abrasive scrolls. As to a TB spacer...junk. Only way I'd get one would be to drill and tap it for a nitrous jet...
VPS
01-11-2003 06:20 PM
