You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Chapter Buy/Sell/Trade Ads: Each chapter will have one (1) thread for chapter members to list items wanted, for sale or for trade.
The rules for posting in this thread are as follows:
Only Ford truck related items and automotive tools & equipment can be listed.
Only one picture is allowed per post, per item. If additonal pictures are necessary, place a link in your post to those pictures. Additional posted pictures will be removed without warning.
You must have your private messaging (PM) turned on and be able to receive PM's to post an ad in the Chapter thread. If you do not, your post will be removed.
Use the PM or email system to conduct all discussion and transactions regarding the item(s). You can post your interest in the item(s) and that you’ll contact the seller but no discussions. Keep it short.
If you post an ad, please reply that you found, sold or otherwise disposed of the item.
The buy/sell/trade thread will be purged periodically for old postings. Generally every 30 to 60 days.
You need to be an active Chapter Member on FTE to post a wanted, for sale or for trade item(s). No Exceptions.
You must have permission from the Chapter Leader or a Regional Moderator to post an ad in a chapter that you are not a member of.
If you are new to FTE (less than 15 days) or have less than 25 posts, you must contact the Chapter Leader for permission before posting an ad.
Your ad or reply to any ad is subject to editing or deletion at discretion of the Chapter Leader, Moderators or Administrators of FTE.
Commercial advertisements are strictly prohibited.
F650 dash mod and new gauges. EGT, Boost, Trans Temp $425
For Sale are some Isspro EV2 gauges and custom F650 dash with high quality Carling on/off switches. I also have several other parts originally intended for my 00 F350 7.3 diesel. Such as: highly desirable Black CPS (2 of them), Intake plenum reinforced inserts, 6637 CAI with a blue Pete's cover, Riffraff diesel FRX (fue rail crossover), used van turbo with pedestal. I can't remember what else? If I don't have pictures, I will take them and email you.
__________________
Torr "I live where you vacation "
2006 F250 King Ranch FX4 Crew 6.0 diesel 4x4 152k miles
4"MBRP SS409Turbo back,SCT3 canned tunes,Sinister Coolant Filter,CAT ELC,Blue Fuel Spring,$10 DIY Harley, Fumoto,Torque App
does that dash go on the lower part of the dashboard over the doghouse? test drove an F350 work truck that had that crazy square opening, but it didn't have a panel in it like that.. i wondered what it was for. no gauge holes though.
It goes below the main dash. Takes the place of the small cubby hole below the electronic 4x4 switch. The top right hole is for the cupholders. I was going to use it on my truck, but I have the upfitter switches.
__________________
I've got a set of Ford OEM chrome plated over aluminum nerfbars for a crewcab. Fits ALL super duty crew cabs. Some scratches and corrosion on the under side. I have all the J clips and bolts, enough to secure it properly. $150
__________________
fordblueheart, what gauges are those. boot, egt, ect...?
EDIT: i see the middle one is egt, and it looks like a 0-40psi boost on the right and a trans temp on the left?
__________________
Eric S.
1994 Ford F-250, SCLB, 7.3L IDI Factory Turbo, 2WD, E4OD, 4.10 LS.
ARP Head Studs, 60-1 Cold wheel, Superduty e-fuel, AEM Dryflow, home made 3" exhaust outlet, 4"exhaust, some gauges(7)
Quote:
Originally Posted by RacinNdrummin
I still stand by the dodge comment... no DB pump is going to turdcloud as bad as a dodge....
