351W engine swap
Popeye69,
My brother and I are doing the same 351W conversion on his 67'. The only diferences is that we are not running power steering, AC and we will be using a floor shifter for the C6. We are using some small block towers out of a 70's moded F100 (Small block 302 style was not offered until 70'). We are currently a week or so away from intalling the motor as we are working on the wiring for the electric fan, fuel pump and MSD 6A as well as straigthening out other debacles. We have installed the towers and they seem, by all measurements to work (will send a post after we install the motor). As for the radiator, we bought a new DP1433 3 Row from Radiator Depot in Dallas, TX for $150.00. We will have to drill holes, but it fits in the radiator channel.
Hope this helps,
J&T's 67
Hope this helps,
J&T's 67
Popeye67,
Also, The engine that we are using came out of a 80ish model PU. We have some large bracket plates, as well as Alternator brackets that we took off of the motor and will not use. Not sure if the 390FE brackets and plates will work, however, if you are interested in the brackets that came off of our engine, let me know.
Thanks,
J&T's 67
Thanks,
J&T's 67
'77hiboy
06-27-2008 07:22 PM
FordRacing2
15
08-12-2003 09:39 PM
