You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
I have an 04 F-250 which of course didn't come with the hood liner. And I didn't notice it when I was buying it. Made me think about it tonight while I was getting diesel. As I was sitting there, I noticed the water seemed to steam off the hood pretty good. So I've been considering buying a stock liner, but remebered seeing the dynamat exterme hood liner a while back. Would do the same purpose as the stock liner (protect the hood from engine heat) plus it would cut some of the engine noise down. Both would end up costing about the same. So which would be better to get? Would the dynamat hold in too much engine heat (i.e. bad for the turbo). Anyone have experience with the dynamat liner?
__________________
Tony
'04 F-250 PSD 4x4 Crew True Blue
I thought about the same thing since my XL came with out the factory liner.
I did dynamat the interior but in the end i just put the factory liner on under the hood.
I was worried about retaining too much heat.
Seemed to me that it would cost more to use the dynamat stuff.
I highly reccomend it for doors,floors,back wall, roof and firewall but its a pain to put on correctly.
Out of all the dynamat products i have used the extreme is the most heavy duty.
Another company makes a VERY similiar product called "brown bead" and it avaiable online for WAY cheaper.
Do a search and check it out.
Tell me more, I have read about it...want you real world opinuion...all you can!
__________________
Administrator
tim.lamkin@internetbrands dot com
Life is not only time……paradoxically, it is the denial of time!
What lies behind us and what lies before us are tiny matters compared to what lies within us.
When you are down...look up...get up...and don't ever give up....
OK.
Since buying the 6.0 meant for me that had to go with a more base model truck,ie, no lariat or KR i figured Ford would skimp on the fixings .
I have the rubber interior.
I removed it and wiped all metal with rubbing alcohol.
Bought $300 of dynamat extreme and went crazy.
There was only i little carpet pad under the rubber for acoustic deadening.
Certainly not enough for a diesel and since i was putting in a sound system i wanted to make it quiet as possible.
The most flexy piece of chasis is the back wall.
If you can push on i and it moves then it needs to be more dense through the application of brown bead, dynamat etc.
I know you would like for me to produce some stats like roadnoise before and after but all i can do is tell you my honest opinion.
VERY well worth it.
Yes it is a pain to do but if you ever wanted to install a stereo or steam clean your carpet removed from the truck now is the time.
Other materials are on the market that you can spray as opposed to peel and stick.
THe dynamat extreme is the most thick out of their products.
I would just get the most thick brown bead and save a few bucks.
Not only does it add density but also has thermodynamic properties so they do sell special cuts for the roof and hood to repel heat but i got bogged down with other mods and short on time and money
You know how that goes.
SO, i do reccomend it but only if your going to take the time to do a thorough job.
Slapping in a few pieces isn't going to be night and day.
Being a little emphatical and covering everything that is metal will be.
Even with a downpipe, catback and tuner most people who ride in the truck can't believe how quiet it is.
Until i crack the window and stomp it!
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
