ABS Codes
Same question
I have the same question. I know this is an old thread, but maybe by me responding, i'll get some attention to this question. I took my car in to read the ABS codes and they came back with a C1155 and a C 1102. Sounds from what i've learned about the C1155 code, all you have to do is replace it. Maybe the same deal with the C1102?
Is there any reason these codes may be going off? Any other potential problems or fixes i need to make other than simply replacing them? Also, if anyone has any information about where to find these sensors, how much they cost and how to change them, i would greatly appreciate it.
Thank you!
Thank you!
Thank you!
Thank you!
Could be a number of things, like corroded or damaged electrical connector pins/sockets, damaged wiring, bad sensor, or maybe the sensor or tone ring are fouled with debris, or rust.
Put it right & see what happens with the C-1102 code, for the ABS acceleration switch circuit failure. I believe it's mounted on the drivers side frame rail, back below where the divers seat is, close to the fuel filter. Check it's wiring & electrical connector pins/sockets for corrosion, ect, or it could be a faulty sensor.
Did this problem come about after some event, like an off road session, or driving on the beach in salt water, ect?????
