80mm maf
80mm maf
will a 02 mustang cobra 80mm maf work on a 01 f150? also, i thing that it works with 24 lb injectors. i believe i have 19 lb injectors. does this mean if i use it i need 24 lb injectors? or will i just need a retune? i know am tring to learn as much about my truck as possible to increase the power. so any informantion will be used for that. thanks.
furrby
furrby
i am porting a stock elbow to match a 75mm tb. when that is done i am going to install the 75mm tb and the elbow at the same time. i have been looking a cams. i like the look of the comp cams xe262ah cams, but the plan is to add a supercharger in about another year and half. so i don't know if they will work with a supercharger. i feel that with a chip it will all work well together. i wanted to go the 24 lb injecters to help with that tune later on. i am still learning about my motor and what can be done with it.
furrby
furrby
I believe that CompCams has supercharger cams as well. I would install them if you are going to supercharge later on. I would get a Lightning MAF. and possibly a Lightning PCM when you get the supercharger. Then get a custom chip or tuner program from DiabloSport. 24# injectors will work fine for what you are wanting to do.
furrby
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
09-18-2005 12:48 PM
