What is the "injector service"
I never take mine to a dealer for maintenance, EVER!!
My girlfriend took her new Civic to the dealer for a 10K maintenance and they charged her $400 for service. They did an oil change, that's it. I looked at the reciept and they charged her to "look" at everything else like A/C, brakes, engine, etc. They didn't actually do any work whatsoever. Huge ripoff.
Another story, my Grandfather took his PSD in for warranty work, and asked them to also change the oil and air filter. On the reciept they charged him almost $100 just to change the air filter. He was a weee bit upset
What you realy need at 30k..
Trans service if you tow. If not, let it be till 60K.
Transfer case oil change, towing or not.
Check front and rear diff. Drain and fill only if contaminated.
Check front brake pads. If your hard on brakes or tow alot they will be about 70% worn.
Lube 4~5 grease fittings. Chang engine oil and filter if needed. Replace your fuel fiter and air filter if needed.(more than 15k on them.) Do not blow out your air cleaner. Replace it.
i am a dealer tech and have been in several times for warrenty work on my cars and trucks and had the the dealer say you should have this and that done . i don't own deisels so its usally need you need a decarbon, injector cleaning and your throttle body cleaned, these are dealer rip off items that are not in the owners manual for any brand that i have read about. some one correct me if i'm wrong but each time they said this it was 2 hours of labor here. how do you clean a diesel injector as far as i know you don't when they go bad we replace them with a rebuilt. in my shop. not untill. every now and then a customer askes should i add a cleaner, on a gas motor we tell them it doe not hurt to add such a brand," think any tech knows which one i mean" or this brand of diesel additive. the only thing we tell a customer is add antigell to their diesel as we never know whats in the ground in the very cold months.
as a tech i will say that i personally feel if its not in your factory manual don't let them sell it to you .save your cash. for me i change my oils every 3500 miles,rotate tires every other, air filter at 15k, cabin air or pollen filter at 20k.every thing else is by the book unless its needed
I have a 2000 X with a v10 im the second owner and I had to get the Fuel injector cleaner done on mine. There was a missfire on every cylinder, I could have swore it was one of the coils. The trucks only got 43,000 orig miles on it, It sat too long and the gas I think gumed it up. The fuel injector cleaner from the dealer near me is not a bottle thing, but it did the trick...the truck runs like a champ now.They charged me $250 here in Ohio for it, injector and throttle body clean. The truck was sputtering very bad idle was great though...and through no codes at all.
Thats my 2 cents
Thats my 2 cents
blackx
that is one time i would say go for it as it saved a bundle not having to replace injectors when it comes down to a missfire and the coils and injectors check out with a ohm meter my guys will try to clean the "gas"injectors as a stop gap. will it work. yes 90% of those cases it works and lasts. it is not something we do just to get more labor ontop of a tuneup to pad a bill. i've heard from people who said i had my 4.0 jeep in for a tune they charged 4 hours labor total. for a inline six come on that is why dealers are called stealerships and those good ones take the heat. maybe i'm to old and don't like hearing of people being ripped off, each labor op has a reason for its use . injector cleaning as you went though was a good call if it did not work at least the dealer or shop was truthfull and tried
A Contrarian View
I used to think this was a rip off as well and perhaps all they do is put a bottle of something in, however, I had a Chevy dealer do an "injector service" on an '01 Duramax when it started getting worse gas mileage and acceleration seemed a bit sluggish. Dealer noted that diesel fuel in the US is fairly "dirty" and the recommend regular cleaning. My truck had around 60,000 miles on it at the time. I can tell you that my experience was it made a very noticable difference in throttle response and I picked up around 2-3 mpg (back up to 17-18 combined mileage I got earlier). I will now make it a regular thing for my truck every 40-50,000 miles. I've been converted at least with diesel engines.
Are you lost? You did know that this is a Ford Trucks forum didn't you? Your Chevy dealer may "note" that diesel fuel is "fairly dirty" but so what, that is what engine filters are for. Maybe he is used to Chevy problems and gulible Chevy owners. The final fuel filter in a PSD is a 2 micron filter, if used withe the stock regulator and stock return system. Even on a regulated return is is near that 2 micron level. That is about as good as you will get, or need, on any engine. Fuel filtered to that level won't wear injectors out. And if it did no amout of injector service would help, it would be time to change injectors. Diesel injectors don't need a snake oil injector service, dealerships do it is called easy money.
